12-01-2021, 11:40 AM | #127 |
i have done alot of work first the spl parts kit and then the mcs 1 way kit and camber plates so havent had alot of time to do testing yet first day out i was a bit slower at fontana but alot of new parts to get used to lol now im buying a house so may not be at the track too much
08-24-2022, 01:27 AM | #128 | |
Drives: Track prepped 2018 Camaro ZL1 (a10) Join Date: Aug 2013
I have to say that unfortunately my experience with the quality of the SPL parts has not been very good so far, one year after putting SPL front lower control arms in my car my alignment shop noticed a rattling noise in the front suspension when going over inconsistencies in the road, I had also noticed this for the past year but thought perhaps I was just being too picky… however after inspecting the car they said there was excess play in the bushings from the lower front control arms. SPL sent me new bearings under warranty free of charge for the parts however the new bearings had the same amount of excess play in them as the previous bearings had. They did not cover any of the labour or the extra alignment I had to do. The new bearings did not reduce the excess play. A few months later I got around to ordering a 2nd set of new replacement bearing, but this time at a cost Because they claimed that there was premature wear in the bearings because of how they were installed and set up during alignment, however while they may have been right about the installation and alignment, they could not have been right about the premature wear because the brand new bearings they sent me immediately had excess play in them and had not improved the situation one bit… Again I had to pay for labour and alignment, this time the new bearings had no excess play and the rattling sound in the suspension over imperfections and the road was finally gone. While I’m happy that the issue is solved, and I will say SPL had a quick response time and detailed information, I shouldn’t have had to pay for any new parts or in my opinion any labour considering the fault was clearly with the product and the quality control issues of the bushings themselves. That added up to a fair bit of money probably $1000 plus being just a pain in the butt waste of time and energy. On top of that, the toe lockout for the rear of the car is not working, repeated alignments show that the rear toe is still moving from .03 degrees immediately after alignment to .3 degrees before the next alignment in only 2 months later
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
08-24-2022, 12:39 PM | #129 | |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
As to how much the link adjusted itself... more than 4 revolutions in one day at Buttonwillow (13CW configuration). Went from toe in to toe out. But only the left side. Maybe because I was hitting the curbs harder on the left side. But it shouldn't happen.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
08-24-2022, 01:12 PM | #130 |
ive had my full kit on for over a year no issues or problems done about 8 or so track days going back to alignment shop friday for a check up
08-24-2022, 02:19 PM | #131 | |
08-24-2022, 02:20 PM | #132 | |
Keep us posted, I hope you’re not shocked with what the alignment specs show
08-24-2022, 03:40 PM | #133 |
I haven't driven the car much since Solo Nationals last year(<1000miles). When I get a chance to get it on the alignment machine again I'll let you know if anything has moved.
08-24-2022, 04:01 PM | #134 | |
yup alot of abuse and track days and keep getting faster and faster i dont think its too far off but well see!
08-25-2022, 07:25 PM | #135 | |
Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
Is it possible it is actually the camber eccentrics that are not holding, causing the camber to get out of spec? Which in turn causes the toe to be out?
08-25-2022, 09:09 PM | #136 |
Drives: 2020 SS 1LE Join Date: Aug 2020
Very interested in hearing feedback as I’m about to install rear toe rods myself!
08-26-2022, 08:52 AM | #137 |
I just had an alignment check and all is good. After installing and torqueing everything you do need to re-check after a few track days. I also have made witness marks that I can inspect to see if anything has moved.
08-26-2022, 06:04 PM | #138 |
Camber bolts didn't move. Paint marks on both sides still lined up. Subframe wasn't deformed. New hardware was used during the installation of the toe links. New hardware is used for every alignment.
09-02-2022, 07:10 PM | #139 |
Lol where’s my help???
09-03-2022, 08:51 AM | #140 |
SPL rear toe rods with eccentric lockout
Just installed them (along with solid subframe bushings) and have a couple questions before I get an alignment. Thanks in advance! 1) The kit came with a pair of bolts and nuts. Do I use them for the subframe side? The instructions state to reuse OEM bolts at both the knuckle and subframe but then I wonder, why did SPL provide these?? * My gut tells me this is an error. They’re probably issuing the same instructions for both the rod-only package and the set with lockouts. 2) Should I use jam nuts in addition to the Allen bolts? If so, what are the sizes and where can I get a set? With one side having reverse threads, I’m guessing no one local store will have hem. 3) I’ve heard concerns of squeaking in the future so I picked up a can of Amsoil HD-MP. I guess I’ll spray some on after the alignment? Anything else I should do for protection? Last edited by Dabjbr; 09-03-2022 at 09:27 AM. |
