07-16-2014, 11:25 AM | #1 |
L99 to LS3 build with blower and cam...need help
O.K. kids, I am taking the plunge and having the L99 built as an LS3 using GMPP ported and polished heads. All of the L99 stuff is going bye bye and of course this means a new cam. My car currently has the E-force supercharger on it which I intend to retain. We are also adding 1 7/8" Stainless Works headers and high flow cats to my existing cat back 3-inch SW exhaust as well. Should make nice power. Now, for those of you who have done this, what cam did you use and how is drive-ability? Which cam did you go with and did you have to change torque converters with your new set up.
Looking for guidance here. Thanks!!
Cars and women are both going to give you problems...but you can pay somebody else to fix your car!
07-16-2014, 12:46 PM | #2 |
Drives: Chevys at the limit Join Date: Nov 2010
With just about any cam that will make decent power, you'll want to do a torque convertor to absorb some of the lope and give you better drivability. It will also keep you in your power band better.
We use the BTR stage 3 and 4 cams in our PD blower cam packages; they drive very well and make great power for being an aggressive cam. We also have a very nice L99-LS3 conversion package with a plug and play front cover. Feel free to call, PM or email me anytime with questions and we'll be happy to help get you setup. Best regards, Tyler 888-308-6007 |
07-16-2014, 01:55 PM | #3 | |
Geek
01000111011011110110111101100100001000000110110001 11010101100011011010110010000001110111011010010111 01000110100000100000011101000110100001101001011100 110010000001101111011011100110010100100001
x = ac97968bd3df8f968c8cd3df998a9c94d3df9c8a918bd3df9c 909c94df8c8a9c949a8dd3df92908b979a8ddf998a9c949a8d d3df8b968b8cd1 x = ~x |
07-18-2014, 08:12 AM | #4 | |
Drives: 2010 RS/SS Join Date: Dec 2010
Sounds like a nice build! I would decide first whether or not you wanted to change your torque converter, and go from there. If you don't want to change your converter, we have a great cam called the Crazy Joe (LINK). It's on the stealther side, and makes great power (here's a blog with it- link, and another - link). Both of those customers are doing superchargers later this year, so we spec'd the cam with that in mind. The performance will be excellent with the blower as well, and both of these cars have the stock converter. Drives just like stock...only difference is it really hauls ass. If you want to go bigger (lopier) on the cam, and have no problem adding a stall, check out our 545. That's also been designed for SC cars and it's like we are installing one a week it seems! I run it in my own TVS 2300 car. Here it is in an L99 N/A car - link. Eforce LS3 car - link. TVS LS3 car - link. The driveability with that (with a converter and a tune) is fantastic also! |
07-18-2014, 08:44 AM | #5 |
Drives: G8 Join Date: Feb 2013
Why would you get rid of the VVT? More power across the entire rpm range is pretty nice!
07-18-2014, 08:51 AM | #6 |
Also, eventually your high flow cats will blow out and stop up the exhaust. They can't handle all the extra flow and heat from FI.
