Old 03-03-2019, 02:16 PM   #1
SanDMaN2091
SanDMaN2091's Avatar
Drives: 2016 Camaro SS A8 NPP
Bad Drive Belt Tensioner=Low Voltage, Bad Charging System, Dead Battery
So I hope this post helps alot if people track down charging problems the cheap way first..
To start off with if the piston on your belt tensioner looks oily and gunked up beneath the rubber boot...it needs to be replaced. Main symptom i had was after night time if i turned off my headlights my alternator voltage would drop to 11v-11.5v (on nGauge)and the car would start to stutter(erratic MAF)with rough idle.
I had taken tensioner off to replace the alternator (and belt) and it had ALOT of snap to it so I didnt see any reason to replace at the time.. but the problem remained so I went ahead and bought a new tensioner (like 80 bucks). After I had installed the new tensioner it came time to break the pulley over to route belt.... it took both hands and much, MUCH more effort..
Cars is a world apart now,.. all accessories and charging system working A1.
Moral of the story.. if your having problems with charging/battery dead and tensioner looks to have been dripping replace tensioner FIRST.....
Pics are of old tensioner on box of new tensioner with good current part#
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
LPE Ported/Polished 95mm LT5Throttle Body,
PRAY Ported MSD Intake Manifold,
SP Coated TSP 1 7/8" Catlless Longtubes
Hooker BlackHeart Cat-Back,
Mishimoto Catch Can (Which always has some nasty in it)
Instagram@Weapon_6
SanDMaN2091 is offline   Reply With Quote
Old 03-05-2019, 05:56 AM   #2
rock45
Drives: car run like tiger
thank you so much you share such a great tips i must follow this your thread is help all people which are facing this issue
rock45 is offline   Reply With Quote
Old 03-05-2019, 08:11 AM   #3
SanDMaN2091
This tip was just too good not to pass on
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
Instagram@Weapon_6
Old 03-07-2019, 12:15 AM   #4
protovack
Drives: 2019 2LT 2.0T M6 Riverside Blue
Thanks, its posts like this that keep this community awesome.
protovack is offline   Reply With Quote
Old 03-08-2019, 08:48 AM   #5
Stex
Drives: 67 goat, 69 goat ram air III
Do you think it was mileage related or just a part failure?
Stex is offline   Reply With Quote
Old 07-01-2019, 01:06 PM   #6
KirkH
I have the exact same symptoms? How big of a job is it to change the belt tensioner? I have air tools and cordless impact tools.
I was thinking that I could buy the Helm manuals for the cost of the repair at the dealership.
Old 07-01-2019, 01:42 PM   #7
SanDMaN2091
It's super easy.. 2 bolts I believe. The alternator was the bbiiiitch... tensioner is pretty tough to break over though I felt like I was going to break it
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
Instagram@Weapon_6
Old 07-02-2019, 02:55 PM   #8
KirkH
Thanks!
Old 07-31-2019, 03:28 AM   #9
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
Thank you. This is very helpful. I am replacing mine because it is leaking. I'm not having any other symptoms for now though.
mrgoodbytes is offline   Reply With Quote
Old 12-21-2020, 07:06 PM   #10
SanDMaN2091
Update: changed for 3rd time today.. they have updated the part no plunger on exterior now thicker piston and hard plastic... maybe this one will last more than 15k
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
Instagram@Weapon_6
Old 12-27-2020, 06:02 PM   #11
Puddin
Do you know if the bolts are reusable or just go ahead and buy new ones?
Old 12-28-2020, 09:19 AM   #12
SanDMaN2091
I've reused them everytime. You dont have to get too crazy tightening them they hold and you dont want to snap one off in the block
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
Instagram@Weapon_6
Old 12-28-2020, 10:16 AM   #13
SanDMaN2091
So when it starts getting cold outside I get alot of questions on replacing this tensioner. I figured a picture is definatly worth a thousand words.
DO NOT REMOVE BOLT IN CENTER OF BLACK PULLEY(It is stationary, and ONLY ment to be tightened)
The Manual says 16 ft/lbs(192 in/lbs) torque spec.. I just snug them down and give them a little bump.. the bolts are large, but lightweight and I dont trust them. It's not worth snapping one off in the block.
Hope this helps everyone out. Winter IS typically when electrical issues like to emerge.
DMS Flex Fuel-E85
HPTuners Ngauge
Roto Fab CAI,
Instagram@Weapon_6
Old 12-28-2020, 08:29 PM   #14
Puddin
Cool appreciate the help.
