Old 09-30-2019, 04:08 PM   #1
collinms
Drives: 2017 ZL1 A10 Summit White
Yikes... Would have thought 190.
https://youtu.be/Zmcw18Iz9Jg
Looks like the aero drag is significant.
collinms is offline   Reply With Quote
Old 09-30-2019, 04:20 PM   #2
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
The comments are funny. Like who cares if it ONLY goes 176ish. That is plenty fast, even for the Ring.
I would much rather have the aero and down force and handling than top speed.
People are so narrow minded and tunnel visioned.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 09-30-2019, 04:38 PM   #3
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Not really a "Yikes" for me...I didn't expect any more. Plus, it sounds like a manual car, and the "regular" manual ZL1 also topped out at 176 in 5th gear. I'm not sure if he went to 6th for this or not which is usable in the ZLE for acceleration. Either way, there are very few road courses (read: basically none) where a street car would be doing 175+ MPH. For normal 1.5 mile, 2 mile, 3 mile etc. road courses, the ZLE/ZL1 will hold its own against the worlds finest street cars.
Old 09-30-2019, 04:47 PM   #4
collinms
Well obviously it's a road course car. I know that. 2.7 mile straight away I would have thought faster is all I'm saying. They say the regular ZL1 will go 198, correct?
Old 09-30-2019, 04:55 PM   #5
Squatch
Camaro pilot
Squatch's Avatar
Drives: 69 Camaro, 2014 ZL1
The A10 will hit 198'ish, (ZL1 non-Aero)...nobody has reported what a ZLE with the A10 will do yet, I'm sure its somewhere in between the 198 and 176 range though...
2014 ZL1 Camaro
1969 Camaro
Squatch is offline   Reply With Quote
Old 09-30-2019, 06:03 PM   #6
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Ive done more than 176 in my M6...
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 09-30-2019, 06:29 PM   #7
Can'tHave2MuchHP
Drives: Fast
I wasn't necessarily commenting towards you, but the idiots in the YouTube comments.
Interesting. Stock? On GPS by chance? What kind of distance are we talking?
Old 09-30-2019, 07:09 PM   #8
Scottyz
2019 ZL1 1LE MY GOON
Scottyz's Avatar
Drives: 1980 Z28 Big Red.
I would have thought considerably more. But... really there is a lot more rolling resistance to overcome with the aero and the wider tires. After all the fronts are the same size as the rears on a regular ZL1 but I’m a little disappointed.
Old 09-30-2019, 07:25 PM   #9
hotlap
hotlap's Avatar
Bill Wise hit 173 on the Ring after shifting to 6th gear at 168 mph.
Ronald Reagan -
Old 09-30-2019, 08:00 PM   #10
Junkyardspecial
I dont know, it was a pull on my local road late at night, showing the friend the car I passed 175 and at that point just paid more attention to the road than the speed. Completely flat road as well and no tailwind.
Old 09-30-2019, 09:11 PM   #11
Revalot
Drives: ZL1/1LE parts added
Location: Somewhere around Texas pines tress and smooth asphalt
I rather have a car that is stable at high speeds ! I hear the ZLE is more stable on the top end, plus if you want to top end it, just remove the tail and carnards.
Revalot is offline   Reply With Quote
Old 09-30-2019, 09:13 PM   #12
Markoz28
Drives: 18 ZL1 nightfall grey A10
Sounds about right. So many factors play into this. Aero and gearing have a lot to do with it.
Markoz28 is offline   Reply With Quote
Old 09-30-2019, 09:22 PM   #13
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
Interesting, I hit 180 on a local road running with bikes, and I wasn't really going for top speed - just trying to keep up with the bikes. After 160 the Aero can be felt in your soul.
viurniel is offline   Reply With Quote
Old 10-01-2019, 09:57 AM   #14
Vigilante375
Drives: 2018 Camaro ZL1
Adding aero like this will cause downforce which in turn will cause the car to "weigh" more so it'll handle better and be more firm to the road.
I do not see why people would think it would go faster in a straight line. The regular ZL1 has a higher top speed because it's more streamlined. Nothing new and same goes with every other car out there that has 2 variants like the ZL1 does.
If you want to go faster (at stock HP levels) then you need to take off your mirrors, add a flat bottom to the entire underside and duct tape your entire front end and you might pick up 5 mph or so. But then you'll also blow up your engine since it's not getting any air to the radiators......
