03-14-2012, 11:53 PM | #1 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
HALLTECH CAI INSTALLED
Installed the Halltech cai on Wednesday. Only took an hour.No instructions but easy and straight forward, also had help from a thread here. One thing I did was instead of cutting the plastic pcv line to the intake tube so it would fit into the rubber hose with the kit, I cut a larger dia hose pc that the plastic line with the fitting attached could slip into and also the rubber line from the kit would also. Worked perfectly and oem line intact.
Initial 15 miles car felt better, easier off the line and accelerated more smoothly, will see after the ecu relearns the new setup.Not much sound, a bit more rumble but exhaust hides most of it.Later will paint the tube gloss black and the box red. More pics in my journal thread also. |
03-15-2012, 12:04 AM | #2 |
IN THE CIRCLE
Congrats! I also have Halltech
I dont want to highjack your thread but here is mine painted. |
03-15-2012, 12:07 AM | #3 |
03-15-2012, 01:07 AM | #4 |
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
Nice flames.
I've had mine for 2yrs now and love it. Jim is a great guy to work with.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
03-15-2012, 11:41 AM | #5 |
Voice Of The Voiceless
Congrats Baron and it looks great!
03-15-2012, 02:37 PM | #6 |
03-15-2012, 09:01 PM | #7 | |
I made a little change to mine. Got rid of the plastic line to the cai rubber hose. Changed out both with a section left over from my catch can. runs from the breather mount on the tube and under the cover to the main metal tube. Much cleaner |
03-15-2012, 10:35 PM | #8 |
I have the same one. The filter hits the hood blanket and has caused damage to it because it sticks up above the air box. Might want to check yours as it looks like it's going to do the same thing as mine. don't know what I'm going to do to fix it yet. Still overseas. Other than that, I think it's a great intake. Congrats.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
03-15-2012, 10:44 PM | #9 |
Da WHALE
Drives: 2014 Stingray, 2015 Panamera 4 Join Date: Dec 2011
Awesome Rick! Looks clean and classy. Enjoy!
Project MantaRay...Underway
03-15-2012, 10:45 PM | #10 | |
Drives: '69 SS Convertible Join Date: May 2009
OP....you should paint the Halltech on the tube either Red, Silver, or Yellow. I did yellow for Yellow Jacket. I used a $6 paint pen from a hobby store. Also, I'm being picky but I personally notice these kind of things. Take off your filter, flip the clamp so the screw is on the other side. Push it down as far as you can go and still reach it with a screw driver. Basically move it so it can't be seen. Same with the filter. Rotate it 180 so the metal strip in underneath and you don't see it. Next up....you need to add an ADM scoop and do a water bottle relocation. http://www.camaro5.com/forums/showth...light=halltech
-2010 Camaro 2SS | M6 | VR w/White Stripes | 1 3/4" KOOKS - 3" Magnaflow | LPE 3.91 gears | ADM tuned | Halltech w/ADM Scoop | Spohn/BMR Trailing Arm/Toe Rod | BC Coilovers| Pedders FE4 ZL1 swaybars | Cradle/Diff/Radius Rod bushings | VMax TB | Morimoto Projectors | MGW shifter | Red Calipers
Build Journal |
03-15-2012, 11:19 PM | #11 | |
I did have to bend the mount bracket that attaches the box to the threaded rod a little, just to keep it forced down as far as it would go. The front pops up alittle but thats due to tolerances in where they put the hole for the tube to pass through.Cant go down any more as the filter end rests on the splash gaurd, but the hood closed takes care of that. |
03-15-2012, 11:33 PM | #12 | |
03-15-2012, 11:34 PM | #13 |
03-16-2012, 09:26 AM | #14 |
Chu no guat a hasa is?
Drives: 14 Jeep G Cherokee Overland HEMI Join Date: Jun 2011
Looks good Rick.
11 2SS/RSL99No Longer Stock (Sold) 6/19/14:AAC Plasma DRL's | Plug n play harness | Elite CC | Tint: 35% & 5% | LED Dome light | Show-N-Go Plate Holder | Flowmaster AT | C.A.I. Intake | VMAX CNC Spiral Ported TB | Husky Splash Guards
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
CAI Inc Intake Are IN STOCK @ Camaro5's #1 CAI Distributor: APEX Motorsports!!! | Apex Motorsports | V8 Bolt-Ons & Tunes | 102 | 05-10-2016 04:19 PM |
Halltech CAI installed :) | wbt | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 244 | 02-27-2012 11:04 AM |
Just installed CAI... | Mikef 2SS/RS | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 09-20-2011 02:58 PM |
Installed my new CAI, inc. CAI!! | eL_777 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 14 | 09-15-2011 02:55 PM |
Flowmaster American Thunder and Roto-Fab CAI Installed | odog | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 15 | 08-20-2010 10:39 AM |
