05-28-2019, 12:55 PM | #1 |
Drives: Camaro 2SS 2017 Join Date: Dec 2018
2017 Camaro SS oil change interval
Hi there!
I wonder abt the need for oil change for very short periods of time. Using the car's oil life monitor, one has to change the oil in about 7 to 8 month period. I drive the car only abt 3k miles a year, so I guess I'll reset the oil life monitor despite not changing the oil to achieve one year period; or in other words, will not care any more for for what the car asks. Consulting with some owners, they take a year period to change oil. What do you think? Is it really necessary to obey car's instructions concerning it? Thank you Adelmar |
05-28-2019, 01:01 PM | #2 |
Drives: 2018 2SS Join Date: Jan 2018
If you're only driving the car 3K a year, then just change oil annually -so yes, simply reset if it is telling you to change and you have not hit the year yet.
05-28-2019, 02:56 PM | #3 |
05-28-2019, 04:27 PM | #4 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
An oil change ones a year is absolutely sufficient enough. Don’t worry what the rest life monitor says.
As long as you’re still in the warranty period I would do as recommended. For me it is almost on the spot. Rest oil life = 1 year give or take a month maybe.
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
05-28-2019, 04:34 PM | #5 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
Once a year is what I do.
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
05-28-2019, 11:32 PM | #6 |
Drives: '17 2SS convertible'20 Yukon Denali Join Date: Nov 2011
You guys need to start driving your Camaros.
Richard
2017 2SS SIM convertible, A8, NPP, MRC, 56R wheels, GM CAI, Diode Dynamics Side Markers Delivered: 08/15/2016 #TeamBeckyD |
05-29-2019, 05:09 AM | #7 |
Drives: 2017 Camaro 2SS, A8 Join Date: Aug 2017
06-02-2019, 04:05 AM | #8 |
Drives: 2018 Summit White Camaro SS 1LE Join Date: Oct 2017
I just completed the first oil change in my 18 1LE.
Looking for some help. I've tried per the instructions in the manual on resetting the oil life monitor. I'm having mental issues trying to bring up the page to reset it. I find Oil Life on the DIC but cannot get it to open. Can someone please give me the instructions step by step. Obviously, I'm not doing it right. Thanks, |
06-02-2019, 04:14 AM | #9 |
"""Turn the ignition to ON position without starting the engine.
Display the REMAINING OIL LIFE on the multi-information display using the navigation button (located on the steering wheel) Finally, hold down the “SEL” button until the Oil Life display changes to 100 percent""". I guess I'm looking for the procedure to get too " REMAINING OIL LIFE " by using the navigation button located on the steering wheel without starting the engine. Thanks, |
06-02-2019, 10:07 AM | #10 |
Drives: Camaro SS 1LE Join Date: Aug 2018
06-02-2019, 10:10 AM | #11 |
The manual says you can also fully depress the gas pedal 3 times within 5 seconds to reset the oil life indicator. (car is in accessory mode of course).
06-02-2019, 10:11 AM | #12 |
06-02-2019, 10:39 AM | #13 |
Drives: 2018 Camaro 1SS/1LE Join Date: Feb 2015
Once per year for me too at around every 3-4,000 miles
06-03-2019, 06:04 AM | #14 |
Drives: 18 zl1 Join Date: Aug 2017
if you change your oil, and let the car sit fresh for a year, the "oil life remaining" will be at 0.
It calculates, among other things, time as well. I drive my car atleast once a week most weeks, sometimes 2 (back and forth to work or weekend cruising), and I usually change mine every 5-6 months, when the oil life reads 30-40%. this usually coincides with 3-4k miles, give or take. |
