View Poll Results: Did you get a Check Engine Light after removing Secondary Cats? | |||
Yes | 5 | 7.25% | |
No | 64 | 92.75% | |
Voters: 69. You may not vote on this poll |
Thread Tools |
05-12-2017, 02:21 PM | #15 | |
Drives: 2016 Camaro 2SS A8 Join Date: Dec 2015
60610 keeps the secondary cats which will require cutting right after them and welding 60610 in place. |
05-12-2017, 08:32 PM | #16 |
Black lightning
Much more pops and gurgles!!!!
And twice as more with the MUFFLER delete. In addition tob the cat delete!!!!!!
[ 2021 Camaro ZLE 10 speed
05-15-2017, 09:12 AM | #17 |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Got the Cats deleted friday after work and I love it!!! The shop had a flexible head welder and did a very good job! I have no CEL's and I love the bump in volume. It's perfect for me. I leave the fuse in and the wife greatly appreciates me starting it up in stealth mode.
I strongly recommend this mod to anyone who wants to slightly increase the volume of the exhaust but still retain the ability to use stealth mode. I think this makes the car about as loud as a typical cat back system for much less money and retains a very quiet stealth mode.
MJK3888 Instagram Link
05-15-2017, 10:01 AM | #18 | |
Drives: Challenger SP Shaker/Arcadia Denali Join Date: Jan 2016
05-15-2017, 12:03 PM | #19 | |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
If the shop uses a sawzall to cut off the secondary cat then it is almost a straight shot with the new pipe to replace the cats and then weld it in. The welding will be a little tight on the top side, but it is doable. |
05-15-2017, 04:16 PM | #20 |
Drives: 2017 ZL1 Join Date: Aug 2016
The secondary cats are unmonitored so you will not get a check engine light removing them.
05-15-2017, 05:09 PM | #21 |
Had mine removed today from a friend who recommended a shop near me that is right across the street from Citi Field for those that are familiar with the area. Thanks for all the insight on this page. So far it sounds better and no CEL so i am a satisfied customer! Total time was about 30 minutes. Went with a 3" pipe as there are no 2.75's in sight. No loss of power feel at all and definitely a great inexpensive mod for those looking a bit more sound out of their exhaust for sure.
05-16-2017, 07:46 AM | #22 |
"M1SS1LE"
In theory yes, but the primary cat monitors will be relatively close to the welds for the cat delete pipes. A bad weld there will allow faulty readings and trip the check engine light. It has happened to others. After watching my shop do the install I would almost caution anyone who tries to get a shop with a non flex head welder to do the install. I think its asking for bad welds.
05-16-2017, 02:54 PM | #23 |
Drives: 2017 Camaro 1 ss, MRC, Dual Exhaust Join Date: Nov 2016
Just got mine done today and it's freaking amazing!!!
05-16-2017, 07:18 PM | #24 |
Drove for a bit today and must say it sounds more pissed off, LOVE IT!!!!! Those pops and gurgles on the shifter are louder and better then ever now. Makes me want to drive it more and more, what a addiction!
05-17-2017, 06:41 PM | #25 |
Drives: 17 Camaro SS2, 93 C1500 Silverado Join Date: Jun 2016
I don't want to thread jack but this is closely related to what i have planned and the forum search gives me an error page...
does anyone know what type of metal our exhaust is made of? and to confirm, it is 2.75" OD? I am doing a muffler and secondary delete with v-band flanges so that they can be swapped to stock config. easily. So if someone could verify before i pull the gun on buying 304SS mandrel tubing and flanges... if its aluminized i could make this project a lot cheaper
17 SS2, Nightfall/Kalahari, M6, muffler delete, skip shift delete, wideband O2, Flex fuel sensor
05-22-2017, 12:08 AM | #26 |
Drives: 2017 Mosaic Black M6 1SS Vert Join Date: Feb 2017
Can you still pass smog with this?
Sent from my SM-G935T using Tapatalk
2017 Mosaic Black 1SS Convertible M6 / MRC / NPP
Magnuson Heartbeat, Rotofab Previous: 2008 Corvette Convertible 2007 Pontiac Solstice GXP |
05-22-2017, 07:40 PM | #27 |
05-22-2017, 08:43 PM | #28 | |
Drives: 2017 Hyper Blue 1LE Join Date: Dec 2016
