04-23-2016, 03:10 AM | #29 |
Drives: 15 Silverado, 15 Corvette 2LT Z51 Join Date: Aug 2012
I'll post the results and a video when my pushrods come in
2016 Camaro 2SS Mosiac Black Aka-The Reaper
Build Thread- http://www.camaro6.com/forums/showthread.php?t=440437 |
04-23-2016, 02:57 PM | #30 |
Drives: SS 6 speed of course Join Date: Jan 2016
are you going to wrench it yourself?
04-27-2016, 11:35 AM | #31 | |
Drives: 2017 1SS 1LE Join Date: Sep 2014
05-02-2016, 07:47 PM | #32 |
Drives: 2016 2SS Black/Black Join Date: Apr 2016
Anyone here done a cam. I realize it's a good bit of work.....was quoted little over $3000 today installed and tuned. Is that the going rate?
05-02-2016, 09:16 PM | #33 |
just a guestimate:
14 hours work $1000 for the cam and springs and I guess a few lifters if you have an auto $400 for the tune.. I guess so. I'll do the work myself just don't know if it is this summer or next.
05-02-2016, 10:25 PM | #34 |
Drives: 350 Join Date: Apr 2016
I wonder what's the total hit of cam and heads being removed. At this point in time, I feel like is a good time to do both and get a full valve train to take advantage of a nice agressive set up.
You can always check out also the henessey camaro, just for guidance on packages and hp expectations. |
05-03-2016, 09:03 AM | #35 |
At the amount of labor required may as well buy the forged drop in wiesco pistons and do those too while the engine is up and out.
Crazy what's required to do a damn cam swap lol |
05-03-2016, 09:26 AM | #36 |
Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
That's cheap for a tune. I'm paying 650 for mine and hell have the car for 3 days.
I like my woman like my milk shakes, THICK!!!!
05-03-2016, 12:41 PM | #37 |
The oil pan has to come off along with cross member which looks to be in two pieces. That said, it is never ending if you are doing pistons, then you should do rods as we are talking 7000 RPM engines at some point. and then C5R timing chain and PP heads, and dual valve springs and pushrods of course and studs for the head and then trunion bearings for the rockers. Just off the top of my head...
05-03-2016, 04:40 PM | #38 | |
Your right. But all those parts hold up to a out 900-1000hp. The pistons are the issue once approaching 650. The ring lands start to come apart on the LT1 |
05-03-2016, 06:17 PM | #39 | |
Plus we all have a definition of holdup. My Type R has 225,000 miles on it and far over 15,000 high RPM shifts (8800 rpm to 9500 rpm) Stock crank, block, bearings and bore. Several sets of pistons and an aftermarket set of rods... If you are telling me a LT1 with stock short bock will last long at 900 -1000 HP, well maybe, we all are different. If I were going to 700 HP you can bet your bottom dollar I would just buy a whole new crate motor to start off with and build from there.
05-03-2016, 06:51 PM | #40 |
Corvette guys have been doing it for a couple years.
It just depends on where and how far you want to go. Fuel is also an issue upwards of 650-700 horse so there's multiple hurdles here |
05-04-2016, 08:55 AM | #41 | |
And if I'm doing the bottom end, might as well look for larger Pistons and add displacement along with a good crank. Heads and cams IMo is a good medium set up all motor in the 500whp range. Things aren't becoming as simple as we expected, are they? Lol As far as tune, three days? Is that because the person is new to the system using a flash ? Sounds like you're tuning a standalone set up lol vs. flash And I thought several hours was enough. |
05-04-2016, 09:04 AM | #42 | |
Drives: 2016 Camaro SS Join Date: Apr 2016
