09-16-2021, 11:18 AM | #1 |
Drives: 2011 Camaro SS Join Date: Jul 2019
Circle D 3200 278 stall to Circle D 245 4c 3800 stall .
Well ive had the 3200 in my car for 4 years now. Its 391 geared. My 60ft is exactly the same now as it was before the cam 1.9. Circle D suggested their 245 mm 3800 billet stall.Does anybody have this converter? Just wondering if its worth the expense. Im on stock rims with Nitto 555r2s on the back. I
nt to go as fast as i can with what i have. Thanks fellas.
EPS CUSTOM GRIND CAM....K@N CAI....VMAX PTB.....FRANKENSTEIN STAGE 2 HEADS ...1 7/8 STAINLESS POWER CATTED LONGTUBE HEADERS...CORSA XTREME 3 INCH CATBACK.....CIRCLE D 3800 Pro Series stall...391 gears.....Ported/modded GPI intake .Forgestar drag pack with Mickey Thompson ET street drag radials AGP PERFORMANCE DYNO TUNED. 463 WHP 428 FTLBS TORQUE.
09-16-2021, 12:08 PM | #2 |
Lots of guys here that made the move from a 3200/3600 stall to a 4k or higher stall that swear it made all the difference in the world, as if the 3200 just wasn't enough. Obviously, the cam factors into this as well. I am fairly certain when I get mine I am going 4k.
09-16-2021, 04:30 PM | #3 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
Probably better off spending the coin on 17” drag radials.
09-16-2021, 07:24 PM | #4 |
I went from a 3200, which my tuner suggested in my build up to the Circle D 5C 4200-4500 single disc per recomendations from a couple guys on here, and Cirdlc D, and man let me tell you, it made ALL the difference in the world on how this beast gets off the line now!! Night and day difference. You whack the throttle now and she flashes up to 6k, drops back down a tad and off we go, the 3200 only flashed to about 3800, dropped down some and was dull until it got over 4200 then it would be ok, but with my curve I needed it way up there in the power band to be more efficient. Had I know this back 3 years ago when we did the build, I would have went bigger that 3200 for sure. But I learned something after 2 years of driving with the 3200. Go big or go home!! lol. One of my friends has a 3600 in his and he says mine feels better than his off the line..
09-16-2021, 08:37 PM | #5 | |
09-17-2021, 12:39 AM | #6 | |
Drives: 2010 SS L99 Join Date: Sep 2018
I have the 5C and it flashes right to my peak torque at 4800 off the line, its nice
Previous PB:11.079 @ 122.99mph.. New setup time: TBD
The 11.079 pass: https://youtu.be/pz27Zq54t_E Build thread - www.camaro5.com/forums/showthread.php?t=555371 |
09-17-2021, 08:20 AM | #7 |
Thats awesome guys.
09-17-2021, 08:30 AM | #8 | |
09-18-2021, 12:12 PM | #9 | |
09-18-2021, 10:26 PM | #10 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
Big Stalls Matter
Retired wanna be cylinder head porter
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter Totalled: 2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X |
09-19-2021, 12:56 AM | #11 |
09-19-2021, 04:26 AM | #12 |
I daily a 5500 with 4.10s
09-19-2021, 07:43 AM | #13 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Are you spinning the whole time? With your mods you should be in the 11’s easily.
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
09-19-2021, 09:01 AM | #14 |
He has a TH400 and is in the 10s
