07-04-2020, 04:14 PM | #1 |
Drives: 2017 Chevrolet Camaro ZL1 M6 Join Date: Jul 2020
Aftermarket Performance Meter
Not all 2017 ZL1's come with a PDR. I would have bought the car anyway, but I thought I had read somewhere that the PDR was offered on all '17 ZL1's
Anyhow, I bought the Pro SS model from G-Tech. It seems to work ok. Any thoughts or recommendations for other performance recorders? Sorry, I think I put this post in the wrong place. I can't figure out how to delete it Last edited by MartinLe; 07-04-2020 at 04:43 PM. Reason: misplaced thread |
07-04-2020, 06:30 PM | #2 |
Sarcasm loading --------
PDR was an option on all zl1's, not standard equipment.
2018 MBM ZL1 1LE - Stock 2014 CRT ZL1 574 rwhp, 537 rwtq - SOLD 2010 IBM SS Camaro VVT L99 w/ TR6060 swap, 489 rwhp, 444 rwtq - SOLD |
07-04-2020, 09:34 PM | #3 | |
Drives: Camaro ZL1 Join Date: May 2020
I was wondering the same thing. I was trying to look into something that goes in the obd port and logs the data but I have yet to stumble across something |
07-05-2020, 11:36 AM | #4 |
Check out G-Tech Pro SS.
07-06-2020, 09:02 AM | #5 |
07-06-2020, 10:24 AM | #6 |
I've read somewhere that using the OBD port for data collection is not optimal. The speed of the data transfer is too slow for accurate logging of information. I don't know if this is correct, it may just be a marketing ploy? After I bought the G-Tech, I found these reviews (see below). They are quite dated, but I think they give a good picture of the company. The latest model appears to be the end result of years of design and testing. I had some questions that I submitted to the company and I received a call from Jovo Majstorovic, inventor/founder of the G-Tech. He told me that his product is used by, I think he said Mercedes Benz and other high profile car manufacturers. Anyhow, he convinced me to continue to use his product. A good salesman or a superior product? Only time will tell. Check out these links: http://www.sub5zero.com/g-techpro-ss...ltimate-gauge/ and https://www.caranddriver.com/feature...-work-feature/. A final thought, what ultimately sold me on the product was the claim of using a 50 Hz GPS engine to track the performance of the vehicle. That tells me the unit should be highly accurate.
07-06-2020, 12:48 PM | #7 | ||
Heres the one I was looking at, Video is just an example I found on youtube. |
07-06-2020, 01:50 PM | #8 |
Just ordered the pro rr version. Will see how it goes. Selected two day shipping so hopefully will arrive by Wednesday
07-07-2020, 04:46 PM | #9 |
Cool. Let me know how it works for you.
07-07-2020, 05:59 PM | #10 |
Arriving Friday, will test it out over the weekend and keep you posted. I am also curious how accurate the hp and torque measurements are, and if they are consistent I plan on adding some boostane fuel additive to get my octane up to about 100 and see if it does any difference.
07-07-2020, 07:09 PM | #11 | |
07-08-2020, 06:55 PM | #12 |
Came in earlier. Seems to be defective. Can’t find gps signal. Been driving for 30 straight minutes. When I go on gps settings screen it finds no more then 4 satellites but doesn’t connect to any. Also has a rattle when you shake it. Kind of like a loose screw inside.
07-09-2020, 03:07 PM | #13 | |
07-09-2020, 03:23 PM | #14 |
Yes I tried connecting the external antenna. It improved signal and found about 6 satellites but it did not want to make a connection with any of them. Yea something is noticeably loose inside. It also does not hold a charge. As soon as the car turns off it goes off. When I start the car I get the message that the almanac or something needs 30 minutes to build. I emailed them yesterday, on their website contact from as well as the email listed for technical support. Have yet to hear back. Kind of nervous to be honest, and disappointed. Was excited to give the unit a try. Really wanted it for this saturday as I was debating on hitting up the drag strip. I also read their return policy stating I would have to pay shipping. But that does not mention anything about defective items.
