05-03-2017, 11:27 AM | #1 |
Drives: 2016 1SS Join Date: Jan 2016
Is it the end of my stock tires?
5/10/17 update - see post #22
After 4 events (8 days) and 10,000 miles the outer shoulders of my front tires is running/ran out ( yes, I just got a new alignment to help with this problem in the future). The center tread still has 30-40% life. Would you run these front tires another track weekend?
1SS, Black, Black Wheels, A8, MRC, NPP
05-03-2017, 12:23 PM | #2 |
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold) Join Date: Nov 2016
hard to tell from these pictures. Are you referring to that gummy surface on outer edges? If so it happens after a few sessions on a new tire and I wouldn't worry about it
What is the current alignment specs? Have you noticed abnormal wear on outer edges?
05-03-2017, 12:30 PM | #3 |
Due to running stock alignment, the outer edge is completely worn out/bald (no more tread blocks. I've just adjusted my front alignment to -2.2
05-03-2017, 12:37 PM | #4 |
Drives: Cayman S or Borrowed 17 1SS 1LE Join Date: Apr 2017
flip them on the wheel and keep running them until they cord
05-03-2017, 12:41 PM | #5 |
No problems with flipping run flats / asymmetric tires ?
05-03-2017, 03:46 PM | #6 |
Drives: 2016 1SS (12/10/2016) Join Date: Jul 2015
I replaced mine when they looked like that (possibly a little earlier actually) for exactly that reason: didn't want to pay for a track day, and find out 1/2 way through I didn't have enough tire to finish the day.
As for "flipping the tires", I'm pretty sure we can't do that. I believe the "outside" of the tire is labeled as such. |
05-03-2017, 04:02 PM | #7 | |
Drives: Sold Join Date: Mar 2017
Yup you are correct, right under the treadwear rating it should say OUTSIDE. |
05-03-2017, 11:33 PM | #8 |
Drives: 2017 SS 1LE, 2016 1SS (previous) Join Date: Apr 2016
One more event should be fine.
05-04-2017, 01:45 AM | #9 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
I would run one more...maybe just be extra conscious of them.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
05-04-2017, 06:00 AM | #10 |
05-04-2017, 06:25 AM | #11 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
It's just me, but i wouldn't run those again. Besides, when you are racing, you want to have confidence in your car, not thinking if a tire will blow or not. Again, that's just what I would do. Good luck!
Kindness and compassion #OthersFirst |
05-04-2017, 10:36 AM | #12 |
Drives: 2017 SS 1LE Join Date: Feb 2013
My driver side tires are starting to look like that even with track alignment. I'll be rotating tires side to side before my next event seeing that most tracks are more abusive to driver side tires. My tires have about 2,500 miles on them. I will get NO WHERE near 10,000 miles on mine.
Also, as FYI, these Goodyear's are not run-flat tires.
2017 SS 1LE (sold)
Nightfall Gray |
05-04-2017, 10:40 AM | #13 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
05-04-2017, 10:42 AM | #14 |
I completely missed the OP's tires are not the G3's.
2017 SS 1LE (sold)
Nightfall Gray |
