12-17-2019, 08:39 PM | #1 |
Drives: 2014 white z28 Join Date: Apr 2019
2014 Z28 19” tires
Will 325’s fit all 4 corners, ok 335’s. Thank you all
12-17-2019, 11:28 PM | #2 |
@MrRaZ28
325's fit, as you asked before. Do not do 335's. They are too wide for the front rims. 325 should be as far as you go.
12-18-2019, 01:02 AM | #3 |
Thank for you reply
12-20-2019, 11:31 AM | #4 |
GRIM
Drives: 2015 Camaro Z/28 Join Date: May 2010
I'm running 325’s on all 4... looks good IMO and other car enthusiasts.
12-20-2019, 07:54 PM | #5 |
Raging Bull Reborn
Drives: '09 CGM Z063LZ '15 RH Z/28 #0631 Join Date: Mar 2012
Michelin Cup 2s
I bought the lightest 325s, a set of 4 325-30-19, they are huge in front.At every cruise in or show folks comment on them, 11.5 - 12” of wideness.
the car corners like a scalded dog. Those are the same tires I have on my vette, except the Camaro bests the 285 width on the front of my z06. Don’t stagger them, as you’ll mess up handling. Read the threads the racers running 325’s will tell you. I also paid to have them heat cycled.. I’ll pull her out and post some pics. I’m going to create my own set of a full rock guard for the front wheel..not the two piece from ZL1 AddOns, I’m asking them to make me a special set. The 325s stickout about 1/2” . I’ve got expel ultimate to keep my paint unchipped by small debris off the fronts.
Toy 1 '15 RH Z/28 w/AC & Radio S/N 0631 Toy 2 '09 CGM Z06 3LZ My DD: '17 Ford Mustang GT Her DD: '14 F150 Ecoboost 3.5 |
12-22-2019, 03:04 PM | #6 | |
Drives: 2015 Camaro Z/28 Join Date: Jan 2011
12-23-2019, 07:02 PM | #7 |
Drives: Camaro Z/28 - 2015 Join Date: Sep 2019
12-24-2019, 09:00 PM | #8 |
Raging Bull Reborn
The cup2 at 315 width add one pound per tire, the 325s add 3 per tire. I said what the heck and went 325 width, the extreme handling in the summer is astounding. Better than trofeo r’s.
I need to redo that 50 mph 180 degree turn again with the 325’s...with trofeo-r’s the car pivoted at 90 degrees into the turn and came out of it going the opposite direction at 55....wow. A friend who owns a 911GT 3-RS couldn’t believe how well it cornered.
12-25-2019, 03:27 PM | #9 |
Okay, thanks.
Is the Cup 2 in 305 also lighter than the Trofeo R in 305? |
12-25-2019, 05:43 PM | #10 |
Paint chips
Thinking of having the bottom of my car wrapped the cars color, just cut out the bad every spring then get redone would this work?
