02-14-2019, 04:26 PM | #1 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Need some help, car won’t go into gear!!!!
So I haven’t driven my car in a while, try driving it today and it won’t go in gear, I try starting it in gear and car just died and now I’m locked in...... need some help.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
02-14-2019, 04:31 PM | #2 |
Maybe bad clutch? I can’t even budge the car out of gear right now. It’s just straight stuck where it is.... I can’t put it back to neutral.
02-14-2019, 04:36 PM | #3 |
Update, car is out of gear, I just started the car and pulled it into neutral. Think it’s the clutch?
02-14-2019, 04:42 PM | #4 |
Watching the trans fluid temp and it’s not going up any? Have never checked it when the car worked just fine but now it’s sitting at 100...
I can move the shifter around when car is off just fine. Just not when the car is on.
02-14-2019, 04:51 PM | #5 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
It won’t move with temps they way they are in SAN unless you are driving hard.
I had a similar issue with my M6. It was related to a bad skip shift solenoid. I assume your tuner tuned out the skip shift for you?
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
02-14-2019, 05:46 PM | #6 |
🤔, yeah that’s cancelled out by my tune. So you couldn’t go into gear because of that?
02-14-2019, 08:10 PM | #7 |
Who fixed it? You know where that solenoid is located? I don’t mind trying to replace it if I can find where it’s at.
