03-30-2018, 10:05 PM | #43 | |
2018 1LE, NASA Instructor
Drives: 2018 Camaro SS 1LE Join Date: Jan 2018
And the best thing about a square setup, I had a 5th wheel and tossed it as a spare. Once I had a flat on track, and having the 5th wheel meant my day wasn't ruined. Are you going to need a spacer in front? Are the studs long enough to engage the nuts with the spacer? |
05-06-2019, 07:49 PM | #44 |
Drives: '18 Black SS 1LE; '01 Corvette Z06 Join Date: Nov 2018
So first, yes I read the whole post and still have a question. Do you or dont you need to buy "camber adjustment bolts" to get -2° front camber? Firestone could only get to -1.6° on the front and the tech handed me a print-out from their computer saying additional parts were needed. After having read multiple posts abd the manual I told him he was wrong. Do I need to apologize?
05-06-2019, 08:04 PM | #45 | |
Drives: E46 S54 race car, 964C2 Join Date: Feb 2017
No, tell him he needs to use a hammer to knock back the camber adjustment bolt on the front strut to get more negative camber. The bolt has splines that make camber changes very difficult unless you back the bolt out past those splines. You can definitely get -2.3 minimum with 100% factory car. |
05-06-2019, 10:40 PM | #46 |
Drives: 2020 SS 1LE (previous: 2017 SS 1LE) Join Date: Mar 2012
+1. I got 2.6 on stock bolts at a dealer.
05-07-2019, 08:11 AM | #47 |
Thanks guys!
05-07-2019, 07:53 PM | #48 |
Drives: 2018 Camaro 2SS 1LE Join Date: Feb 2013
What's the trick to get idiot alignment shops to perform the alignment correctly? I know for a fact having read up on how to perform the alignment with the stock eccentric bolts and holes, that it is relatively easy but time consuming. For some reason the townie couldnt understand that you only need the single eccentric hole in the McPherson strut on the upper bolt hole where it connects to the spindle.
The dude was trying to say that I needed extra eccentric bolts for the front struts and an extra bolt that goes into the top hole of the front spindle, the hole that is perpendicular to the direction of motion of the car. |
05-07-2019, 11:14 PM | #49 |
Drives: 2018 Camaro SS 1LE Join Date: Jul 2018
You get what you pay for...cheap alignment = cheap alignment. I've been forced to go to these shops and attempt to help them by providing print outs of the torque values and what bolts to adjust - this helps considerably. I usually leave on the seat in the car or provide directly to the tech.
In their defense, they are judged on speed, not necessarily quality. They are expected to know hundreds of cars and their computer data bases may not necessarily know the Camaro 'Performance Supplement', etc. An extra $20 goes along ways too...:-)
05-08-2019, 12:43 AM | #50 |
Drives: 2017 1SS/1LE Join Date: Sep 2016
05-08-2019, 04:01 AM | #51 |
Seems to me that tapped hole is used to push the camber LESS negative, so not really a thing you'll likely be wanting when doing a track alignment.
05-08-2019, 06:57 AM | #52 |
05-08-2019, 06:58 AM | #53 |
05-08-2019, 07:46 AM | #54 | |
Drives: ISO ss 1le Join Date: May 2018
I would 100% find a new shop if the tech working on your car can't see that. I'm not terribly far from you and there is 3 shops i'd recommend here in Orlando. Chi and the crew at Dynasty Automotive (probably the closest to you, right off 408 on 50) they do good work, just tough to get them scheduled. Philips tire and Auto in Fern Park, my latest favorite (least expensive of the bunch but they set up all race cars and lewis lets you watch what he's doing), and Drivers Choice in longwood ($130 for an alignment, but they do high end race Porsche's and the like). |
05-08-2019, 07:48 AM | #55 |
Since i have ground camber slots for additional camber, I actually used that hole as a set screw to prevent any slippage of the knuckle back toward the strut.
05-08-2019, 08:22 AM | #56 |
Drives: 2017 1SS 1LE Join Date: Jun 2016
That hole is just for a bolt to help with alignment as Move_Over mentioned. Yes, if you thread a bolt all the way in you'll get more positive camber, but when doing an alignment it's a good idea to put a bolt in there with a little bit of preload so you you can take some of the stress out of the strut/knuckle bolt before pushing them out (helps save the threads/splines). From there you just loosen the top bolt to get more negative camber. This keeps you from slamming the knuckle around under the weight of the car once the strut/knuckle bolts are out and also makes it really easy to dial in the camber to match left and right sides.
2017 SS 1LE.
Thread Tools | |
