04-17-2021, 07:21 AM | #1 |
Drives: Chevy Camaro 2018 Join Date: Sep 2020
Velossa Tech scoop and MAP Kpa
Has anyone done testing with a velossa tech scoop to see if thier claim of higher frontal area pressure equates to better MAP Kpa readings? Makes sense to me if it can slightly pressurize intake area it could improve Kpa closer to 100. I'm seeing 95 to 96 at 6400 rpm.
04-17-2021, 12:42 PM | #2 |
Last year I did add and remove parts to gather some data on this topic. I’m going to update this after I make some changes this year.
https://www.camaro6.com/forums/showthread.php?t=573635
04-19-2021, 02:39 PM | #3 |
Drives: 2018 Camaro SS Join Date: May 2019
I can tell ya what I know.
Before I installed my Velossa ram air my MPH was 92 to 93.5 for a solid year. Spring through fall. Approximately 15-20 runs. The next year the only thing I added was the Velossa ram air. I ran from March to about Sept (near the same amount of runs)and the entire year I averaged 94.5 to around 95 MPH. So from one year to the next with nothing but the addition of the Velossa I seen a increase of 1.5 MPH in the 1/8. My ET was about the same. Maybe little more on cooler days but the MPH was a consistent increase. So take it for what it's worth.
GPI ported LT2 intake
Kooks 1 7/8 long tubes high flow cats Mamo ported 87mm TB CAI cold air box Vellosa ram air MBRP axle back E85 Flex fuel sensor Tuned by GPI |
04-19-2021, 05:04 PM | #4 |
Drives: 2017 Silverado/2017 ZL1 Join Date: Aug 2019
I highly doubt it has any ram air effect, it may possibly have a tiny bit on the stock intake. Once you switch to an aftermarket intake there just no way. Too many places for the air to escape into the engine bay. The only benefit I saw was potentially decreasing IATs.
04-19-2021, 10:10 PM | #5 | |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
I am willing to bet it's 5-10 hp on a stock/aftermarket box that can be sealed (pressurized). The power difference is noticeable. Roto-fab or GM CAI style boxes can not be pressurized and it is a waste of time.
