Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 04-12-2021, 12:34 AM   #1
STYLO LT1
STYLO LT1's Avatar
Drives: 2016 Camaro SS Vert.
Car idling slightly higher after new ported throttle body
So if memory serves me right, I remember my manual 2016 SS idling at 500 RPMs with the stock throttle body. I recently installed a ported and polished throttle body with no increase in size. Now the car idles at 600 RPMs even after doing the relearn procedure. There are no leaks detected and car has not thrown any codes. Will it be okay to be in a slightly higher RPM at idle? I appreciate your input.
STYLO LT1 is offline   Reply With Quote
Old 04-12-2021, 11:09 AM   #2
BrianL
BrianL's Avatar
Drives: 2016 2SS, Red Hot, NPP, Nav, M6
My Mamo V2 PTB still idles at the same RPM after the relearn process.
BrianL is offline   Reply With Quote
Old 04-12-2021, 11:22 AM   #3
ctrlz
Below is from the repair manual. It is in table form and lists hundreds of parameters. I quoted the column headers and the idle parameters:
SPECIFICATIONS > K20 ENGINE CONTROL MODULE: SCAN TOOL INFORMATION
Engine Control Module Scan Tool Data
1) Parameter; 2) System State; 3) Expected Value; 4) Description
1) Desired Idle Speed;
2) Engine Idling;
3) Approximately 650 RPM;
4) This parameter displays the
desired engine idle speed as
commanded by the control
module. The desired idle speed
varies depending on engine
load.
Old 04-12-2021, 12:12 PM   #4
STYLO LT1
STYLO LT1's Avatar
Thanks guys. The only thing I can think of is that the butterfly isn't seating correctly. Either way, the idle is just slightly off. Will it be okay living in that range at idle? Should I just send it back?
Old 04-12-2021, 01:02 PM   #5
Heat Magnet
Drives: 2021 Chevrolet Camaro 2SS
I don't think a 100 RPM increase in idle should be something to worry about. I remember when my dad had his 1980 Corvette fixed up for some mechanical issue, they actually increased the idle slightly since it was pretty rough at the RPM it was at. Just remember, VTEC motors idle at 8,000 RPM so 500 to 600 RPM is nothing.
Cars I own/drive:
  1. 2007 Chevrolet Cobalt LT Sedan
    Ultra Silver Metallic, gold painted wheel covers, 4T45 transmission
  2. 2021 Chevrolet Camaro 2SS Coupe
    Black, Redline Edition, 1LE Suspension Package, 10L80 transmission, NPP, Body color high wing spoiler, Ground effects kit
Heat Magnet is offline   Reply With Quote
Old 04-12-2021, 01:48 PM   #6
Crushin_LT1
Crushin_LT1's Avatar
Drives: 2021 LT1 6spd
Idk I came from a K24 and it idled at around 850 or so, not 8000 lol
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black
Crushin_LT1 is offline   Reply With Quote
Old 04-12-2021, 02:13 PM   #7
m6-lt1
m6-lt1's Avatar
Drives: 2016 Chevrolet Camaro SS
500 rpm sounds kind of low for it to idle at that. I feel like something wasn’t seated properly before the Tb install and during the install you seated it properly and now it’s idling where it should.
m6-lt1 is offline   Reply With Quote
Old 04-12-2021, 02:16 PM   #8
Crushin_LT1
My 2021 M6 idles at 650, I understand the autos idles around 800?
Old 04-12-2021, 03:34 PM   #9
Spaceme1117
Spaceme1117's Avatar
Drives: 2017 Camaro SS, 2011 Corvette GS
Ported throttle body won't seal quite as well as a stock TB and this is likely the cause of the increased idle.
You would likely need a tune to get the idle back to normal.
Spaceme1117 is offline   Reply With Quote
Old 04-18-2021, 04:59 AM   #10
STEVE41
Drives: 2016 SS
a tune can't fix it if too much material is removed around the throttle blade area.
STEVE41 is offline   Reply With Quote
Old 04-19-2021, 08:01 PM   #11
BDPhoto519
BDPhoto519's Avatar
Idle speed changes based on a few conditions... But fully warmed up, at operating temperture and normal-ish outside temperture your target idle for an Auto LT1 is 575 RPM.
2018 Camaro 2SS A8 Redline Edition
BDPhoto519 is offline   Reply With Quote
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
