11-04-2020, 04:34 PM | #1 |
Drives: 2017 Camaro Join Date: Jul 2018
Replacing HMI
My HMI unit is bad. Out of bumper to bumper warranty. Anybody has replaced their HMI units? who can program the HMI unit? can a used one be purchased and installed? thanks in advance!
04-19-2021, 07:17 PM | #2 |
Drives: Chevy Camaro 2SS Join Date: Mar 2019
Not sure if this is still needed, but check with Gen5DIY. They have some solutions that may work for you.
https://www.gen5diy.com/ |
04-20-2021, 02:46 PM | #3 |
Drives: 2016 Camaro 1LT Join Date: Jan 2016
what makes you think the hmi is bad?
As opposed to say the display being bad.... or a cable between the two being loose/damaged? |
04-20-2021, 06:21 PM | #4 |
I figured it out. It was a bad HMI. I checked cables and voltages. I did go with gen5diy. They programmed it and did the front camera upgrade. It's working like a charm. Thanks for replying.
09-12-2022, 07:34 AM | #5 |
Drives: Chevy Camaro Join Date: Sep 2022
Replacing HMI
Can you expand on what they symptoms were before you replaced the HMI?
Have a 2017 Camaro SS the screen went black and doesn't work when touched and neither do the physical buttons below the screen. Disconnecting the battery for a while does nothing. |
Thread Tools | |
