11-02-2020, 05:50 PM | #15 |
Drives: 2018 Camaro 2SS, redline edition Join Date: Jun 2013
@FH212. How early does the dealer let you do the first oil change?
Also, did you get the NPP exhaust system? If so, did you pull the fuse? I'm wondering if that still works without getting a CEL? |
11-02-2020, 07:44 PM | #16 |
Drives: 2021 Camaro SS 1LE Join Date: May 2009
Not sure. I am not bringing it to the dealership. I bought the Mobil 1 0-40 Dexos and I will be getting it changed at a local speed shop Friday. I don’t want this car anywhere near a dealership unless it has warranty work. Yes all the 1LEs have NPP. I have not pulled the fuse on this one but I did on my 2017 and it never had any CELs? So not sure......
2021 Camaro 1SS 1LE - Red Hot
2015 Camaro Z/28 - Red Hot 2001 Mecham Trans Am #3 - 7.0L LS1 |
11-03-2020, 05:43 AM | #17 |
I know the feeling about not trusting a dealership
Thanks for getting back to me. |
11-03-2020, 05:47 AM | #18 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
My 2021 LT1 has 250 miles on it now and so far ok.
11-05-2020, 12:24 PM | #19 |
Drives: 2021 LT1 Camaro Join Date: Nov 2020
new rs
well i just picked up a new 2021 Camaro LT1 friday and Saturday with 36 miles it started to miss and is in the dealer now. Problem broken valve spring.
11-05-2020, 12:59 PM | #20 |
376 cubic inches of fun
Apparently the way GM plans to purge defective springs is to keep using them for production and replace them as they fail, at the customers' inconvenience.
That's how they dealt with AFM lifters in the last decade, which were used in millions of cars and light trucks long after the defect was known. |
11-11-2020, 11:58 AM | #21 |
Drives: 2021 1ss a10 Join Date: Aug 2020
21 1SS A10 built 9/22. Have 950 miles on it. Keeping it under 4000 rpm as directed for break in. All good so far. Knocks on wood.
2021 1SS A10 NPP
11-11-2020, 01:43 PM | #22 |
Dantesab: When was your build-date?
11-13-2020, 12:37 PM | #23 |
9/20
Just got it back yesterday they said #7 cylinder spring broke. I thought they would replace all 16 but they only replaced 8 on the side of the broken one.,. Damn talk about cheap I told the dealer if the other side brakes you will get this car through your front window. How stupid can you be: |
11-13-2020, 01:16 PM | #24 | |
https://gmauthority.com/blog/2020/09...gm-v8-engines/
11-28-2020, 12:22 PM | #25 | |
I would find another dealership and get the other side replaced. |
11-28-2020, 02:34 PM | #26 |
Another C8 owner went BOOM at 1000 miles. I was hoping by 500 miles i won't have to worry anymore. I am at 430 miles now.
11-28-2020, 05:35 PM | #27 |
I was hoping for that also. I am at 550 miles. Fingers crossed....
11-29-2020, 09:17 AM | #28 |
It appears a stroke of good fortune that HPE replaced mine with dbls
'20 ZL1 1LE A10,
