Homepage Garage Wiki Register Members List Social Groups Calendar Search Today's Posts Mark Forums Read
Old 02-10-2018, 05:56 PM   #1
Retro69
Retro69's Avatar
Drives: 2018 Camaro ZL1
5th Gen Z/28 Wheels on 6th Gen ZL1
I'm preparing to sell my 2011 SGM 2SS and buy a 2017-2018 ZL1. I have a set of 5th Gen Z/28 wheels that I would like to use for autocross on the ZL1. Will these fit?
Retro69 is offline   Reply With Quote
Old 02-10-2018, 06:35 PM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: 2018 Camaro ZL1 A10
Are they OEM Z28 sizing or are they 10" (Front) 11" (rear) which is standard 1LE/ZL1 measurements? OEM Z28 wheels are 19x11 and 19x11.5 for front and rear respectively.
OEM 5th and 6th gen ZL1s sizing is 20x10 and 20x11, if they're those measurements, then they'll fit. If they're 11" and 11.5" OEM Z28 wheels, then I don't know.
Old 02-10-2018, 06:40 PM   #3
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
I want a set for my car so I have looked into it. They will fit, a few guys here are running them on zl1 1le's. On mag ride cars the front fitament is tight so you can not stray from the factory camber without a spacer.
Mcmillion is offline   Reply With Quote
Old 02-10-2018, 07:05 PM   #4
Can'tHave2MuchHP
Yes this is true if you're talking OEM sized Z28 wheels (11" fronts, 11.5" rear).
Old 02-10-2018, 08:09 PM   #5
Retro69
Retro69's Avatar
There are OEM Z/28 wheels so it sounds like I'm good to as long as I keep factory camber.
Thanks Y'all.
Old 02-10-2018, 09:45 PM   #6
Can'tHave2MuchHP
Originally Posted by Retro69 View Post
There are OEM Z/28 wheels so I it sounds like I'm good to as long as I keep factory camber.
Thanks Y'all.
Post pics when you get them on. I'd be careful at first, until you test with a load, spirited driving, warmed up tires etc. but if that checks out then let er rip.
Old 02-11-2018, 03:10 PM   #7
Retro69
Retro69's Avatar
Will do! Now I just have to find a car
Old 03-29-2018, 07:37 PM   #8
Retro69
Retro69's Avatar
So here’s the verdict. Yes! Conditionally.
Provisionally because there is only about 15/64” between the front wheel and the strut. *Might* be okay but I think I would run a thin spacer. Grinding away just a tiny bit of the strut would work as well. What do you all think?
Old 03-29-2018, 08:25 PM   #9
2010REDSS
2010REDSS's Avatar
Drives: 2018 ZL1 1LE and 2015 Z/28
They work great on the ZL1 1LE.....as there is more clearance in the suspension of course.
If they are that close on the ZL1, I'd consider grinding the strut a bit. You'd hate to tear up a wheel under suspension compression.
2018 ZL1 1LE "RAZECAR"
2016 2SS Convertible "NOTOPSS"
2015 Z/28 #306 "ITZFAST"
2010 2SS Coupe "FASSTER" (Sold)
2002 SS/RS "02FASST" (Sold)
2007 Factory Five Racing GTM "REDBLUR"
"There are two kinds of cars. Red....and everything else!"
2010REDSS is offline   Reply With Quote
Old 03-30-2018, 06:42 AM   #10
URBAN LEGEND
URBAN LEGEND's Avatar
Its need to be lowered to close the gap.
🔺19 A10 ZL1-1LE (Delivery 3/27/19)
🔺19 Audi E-Tron
🔺20 BMW X3M CP
URBAN LEGEND is offline   Reply With Quote
Old 03-30-2018, 09:07 AM   #11
cdb95z28
cdb95z28's Avatar
Drives: 2014 1SS 1LE NPP Recaros SIM
The Z wheels look great on a ZL1 and ZL1 1LE.
Grinding the MRC strut has been covered. Check out these threads and others in the 1LE forum:
http://www.camaro6.com/forums/showthread.php?t=487124
http://www.camaro6.com/forums/showthread.php?t=486305
http://www.camaro6.com/forums/showth...32#post9590532
There is nothing wrong in using a spacer to gain clearance, so long as you buy quality and sweat the details (longer studs, hub and wheel centric, lug nut engagement, etc). I’ve used them for years at the track and street.
2014 1SS 1LE NPP Recaros SIM-Build Thread:http://www.camaro5.com/forums/showthread.php?t=395103
My Instagram: https://www.instagram.com/roadracing3/
2010 GMC Sierra 1500 Crew Cab SLE 5.3L-Hauls stuff
2009 Pontiac G8 GT-SOLD
1995 Chevrolet Camaro Z28 5.7L-SOLD http://www.camaroz28.com/forums/cars...-c-lt1-691328/
2012 Chevrolet Traverse LT-Hauls Kids
1981 'Vette-Chevette that is, "Yeah, I had a 'Vette"-SOLD(obviously)
1984 Chevrolet Caprice Classic/1991 Chevrolet Caprice-Old man cars while I was in my 20s & 30s
cdb95z28 is online now   Reply With Quote
Old 03-30-2018, 11:02 AM   #12
Retro69
Retro69's Avatar
Thanks for the links!
What’s the generally recommended clearance? Somewhere I recall hearing the diameter of a pencil.
Old 03-30-2018, 11:52 AM   #13
cdb95z28
cdb95z28's Avatar
Yeah, Pete from JPSS has always said a #2 pencil width which is about 7mm.
Old 03-30-2018, 11:55 AM   #14
cdb95z28
cdb95z28's Avatar
I thought your user name sounded familiar, you had the Synergy Green 5Th Gen and Z suspension. Nice upgrade!
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
