Old 09-15-2020, 07:22 AM   #15
ember1205
Hot Camaro
ember1205's Avatar
Originally Posted by Yves ZL1 View Post
Si what can I get ? 🤷🏻*♂️
Do you have any type of hardware store in your area? Take one of the factory screws out of the bumper cover and take it in to the store to have them match it against something else that is longer (to whatever length you determined would be necessary).
Old 09-16-2020, 01:30 PM   #16
Yves ZL1
Yves ZL1's Avatar
Drives: Canadian 2019 BLACK ZL1
Yes .. that’ s what I would like to do but thé screws in France are in centimèters and not inches ...
Thé other thing is il think there is a clip on which thé screw is fixed ? I’m afraid to not to screw it correctly... it’s not easy to put it in the hole... ever lost a clip ...
Yves ZL1 is offline   Reply With Quote
Old 09-16-2020, 01:35 PM   #17
ember1205
Hot Camaro
ember1205's Avatar
I don't think you'll have an issue with SAE versus metric so long as the pitch and thread count matches. Step 1 would be to match the threads as closely as possible. Step 2 is to get the correct length, regardless of the measurement system being used.
The way these go in, if I remember correctly, is that there is a "generic" hole drilled through the component "inside". A speed clip is snapped over that hole to provide a threaded receiver for the screw to go into. Those clips can and do fall off if there is no screw in them, but otherwise should remain in place.
Speed clips are sort of rough gauge in terms of threads and will give and flex a little to accommodate thread pitches that are not perfect matches.
Old 09-16-2020, 01:46 PM   #18
ZED SLED
ZED SLED's Avatar
Drives: 2017 Mosaic Bk ZL1 M6
Most likely the factory screws are metric so you shouldn't have an issue. Any body screws I've ran across on these cars are metric. That's why we have a joke about a 10mm socket, lol.
Old 09-19-2020, 02:51 AM   #19
Yves ZL1
Yves ZL1's Avatar
Ok guys Really Thanks for helping... let you know as soon as I put in thé screws Il’´ buy...
Old 09-19-2020, 02:52 AM   #20
Yves ZL1
Yves ZL1's Avatar
That’s what makes me fear... because sometimes it s really hard to put thé screws in those clips and sometimes you lose thé clips...
Old 09-19-2020, 11:04 AM   #21
h018871
Geoff
h018871's Avatar
Drives: 2020 ZL1 Green
possibly another option
Yves
You could use the stock/factory screw and mount the license plate the way that the ZL1 1LE is mounted. no spacer is needed.
File Type: pdf License Plate Instructions SNS 101a 2018-2020 Camaro ZL1 1LE.pdf (1.17 MB, 100 views)
Old 09-20-2020, 07:03 AM   #22
ember1205
Hot Camaro
ember1205's Avatar
While they could slip off while you're trying to install the screws, it's unlikely and they wouldn't be "lost" really... Clip them back on and try again. As long as the pitch of the thread is at least very close, there shouldn't be an issue.
Old 09-20-2020, 02:56 PM   #23
Yves ZL1
Yves ZL1's Avatar
Ok thanks
Old 09-20-2020, 02:59 PM   #24
Yves ZL1
Yves ZL1's Avatar
Originally Posted by h018871 View Post
Yves
That’s Exactly what I’m Train-train to study..
Thanks a lot for your advices .. great super Thanks
Old 09-22-2020, 04:00 AM   #25
Yves ZL1
Yves ZL1's Avatar
Just a thing... could you tell me what is the thivkness of thé plaque (the one with two screws on the Previous pic)
Thanks
Old 09-22-2020, 08:16 AM   #26
Yves ZL1
Yves ZL1's Avatar
Even if you could Give me the measures
Lenght, thicknesse, width of the plaque....
RealThanks
I bought iron and screws... and a friend of mine is going to weld a similar system.
Old 09-22-2020, 12:00 PM   #27
h018871
Geoff
h018871's Avatar
mine is made out of 3/32 inch thick aluminum plate ~ 2 - 2.5mm for you. as far as the rest of the measurements, cut to fit the existing holes and stay behind the little air dam.
in american 'easy peazy'
Old 09-22-2020, 02:47 PM   #28
Yves ZL1
Yves ZL1's Avatar
Ok so the thickness is nearly 2,3 mm
Thé lenght, I thought about 17 cm and three cm for the width...
