10-22-2018, 08:26 AM | #71 |
Drives: 2017 Camaro 2SS Vert Join Date: Mar 2013
I guess I will wait to take mine back in then. The TC flush did nothing, the TC replacement was a joke, had the rear end replaced next... yep still have a shudder. For the mean time I will use my paddle shifters as when I am in manual mode the shudder is gone which as a non mechanic seems to make sense to me if I am understanding the purpose of a TC. Here's to hoping that GM comes out with an actual fix, I'm just glad I only have 10k miles on mine so I have time in my warranty for them to figure this out and if my transmission takes a dive in the mean time I can get it fixed under the warranty. Really wishing I had kept searching for a manual transmission when I bought mine.
Luna
2017 2SS Vert |
10-23-2018, 06:57 AM | #72 |
Mine has gotten progressively worse since Friday when I took it to the dealership and they confirmed it. It is bed enough I do not even want to drive it. Waiting on a call from the dealership to see when they can put me in a rental car, plus the did not fix the squealing belt or tensioner from the last time it was in for repair. Will have to play the waiting game now. :(
10-23-2018, 10:35 AM | #73 |
Drives: '17 2SS, NGM, MRC, DPP; '19 F150 Join Date: Apr 2017
Well, my SS has 13XXX miles, and I had never experienced it until this morning.
Felt like running over a short rumble strip every 50ft and rpms would bounce and drop 50-100rpms each time. Is that what you guys experience? Called my dealer and they said the only "fix" at the moment is flush until Q1 2019, same as the rest of you guys.
2017 Camaro 2SS, Nightfall Grey Metallic, Magride, NPP exhaust, VS Forged VS12s in brushed clear coat (20x9 front, 20x10 rear), Michelin PS4’s (255/40 front, 285/35 rear)
10-23-2018, 10:48 AM | #74 |
Drives: 2SS, Hyper Blue, Sunroof, NPP, MRC Join Date: Jul 2016
I'll find out what they say on Thursday when I'm back for round 2. The flush lasted about 8K miles. That should get me till next summer. The big question is will this still be covered under warranty? By that time I'll be past my 3/36.
10-23-2018, 11:10 AM | #75 |
Drives: 2017 garnet red ss Join Date: Jun 2018
They told me yesterday no more torque converter swaps, I had mine flushed about 4k miles ago. He said they can do a single flush to get me by until this repair is ready. He suspects there is going to be an upgraded converter..lol I hope so. I'm opting to go with an aftermarket triple disk lockup and be do with it.
10-23-2018, 11:10 AM | #76 |
Drives: 2017 Camaro Join Date: Mar 2018
It's under powertrain not the base warranty.
10-23-2018, 11:12 AM | #77 |
Drives: 2017 Chevrolet Camaro 2.0 LT Join Date: Apr 2017
I am dropping mine off in the morning. I am a little above 14xxx, '17 model. Its been doing it a few weeks but I did not realize it until last weekend when driving back and forth helping someone move. with cruise about 60 it would just randomly rumble, like i went of the road. Not shifting, slight acceleration.
10-23-2018, 11:14 AM | #78 | |
That is exactly what it feels like and what happened to me. |
10-23-2018, 11:19 AM | #79 | |
10-23-2018, 11:33 AM | #80 |
I had appointment before seeing the new tsb. im going to talk to them about it in the morning about waiting, but was not clear if it was fine to wait. Is the shudder just an annoyance, nothing long term damaged?
10-23-2018, 12:08 PM | #81 | |
Drives: 18 zl1 Join Date: Aug 2017
stock parts and stock tune won't fix this. If you are shuddering, you can, at best, bandaid it with a new, better built, TC and some good fluid with the proper friction modifier. if you don't flush your tranny fluid, the plate material from the TC will ingress the tranny fluid and possibly cause issues later on, that's why first and foremost they do a triple flush, to get rid of all the material. bad news is, if you wait too long, you can potentially damage your whole transmission because of all the material floating around in your fluid and getting into and on the clutch packs. maybe you'll still be under warranty if that happens. |
10-25-2018, 12:54 AM | #82 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
10-25-2018, 01:01 AM | #83 | |
If your TC has gotten so bad that the lockup solenoid has a delay to build sufficient pressure to engage lockup, you're doing the same thing to reverse, 1st and probably 2nd gear. All told, the only gears in the transmission that aren't at risk of damage are probably 3-5th -- as even the 1:1 gear (6th) is suffering from the pulse during extended city speed driving. |
10-25-2018, 06:53 AM | #84 |
Drives: 2017 Camaro FIFTY 2SS Join Date: Jan 2017
Here's a question I have and I don't know if I've ever seen it anywhere. Is the torque converter issue and shutter issue isolated only to the 8-cylinder models? If that's the case then it probably directly is impacted buy the active fuel management system
