12-06-2022, 12:40 PM | #113 |
Drives: 2018 Zl1 Camaro Join Date: Feb 2018
Hi SoCal,
Thanks so much for answering all my questions. One last question regarding your Valve covers and relocation kit. I ended up going with the KaTech covers over the WeaponX for two reasons, one KaTech had theirs in stock and two you mentioned their relocation kit works with their Valve Covers. However, when speaking with the KaTech sales dept, they mentioned that only factory coils fit their relocation kit... did you have any issue with the MSD Coil packs fitting onto their relocation kit? Seems to me if the coils are made to replace stock, and the relocation kit uses stock, then it shouldn't matter? Am I missing something here? Thanks again.
Big Gulp|NW103|SW Headers|UHO CATS|XPipe|Borla Atak|MM CC|Kong Ported|NSX|ATI Damper|DSX 9.45 Lower|ZPE 2.5 Upper|DM Tensioner|FW Green Belt/BTR Gen V LT4 Cam w/32% lobe/BTR VVT Lockout/Pratt & Miller Chain/BTR Pushrods,Valve Springs, Retainers, Hydraulic Lifters & Guide Plate, Trunnion Roller|Katech Valley|KaTech Valve Covers|MSD Coils|DSX E Sensor & Aux Pump|ICT Water Pump|Katech Oil Pump|Cordes & Mishimoto Expansion Tanks|P3 Gauge|LC-2 Wideband Sensor|KaTech Wires|DynoJet Tuned
12-06-2022, 10:33 PM | #114 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Can't go wrong with Katech, and im sure Weapon X's are awesome also. I can confirm that the MSD coils are a direct fit replacement. No issues at all. Dont forget the longer wires from Katech. Be sure to share your photos when done!
2022 M6 ZLE: Katech CNC Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild CC Coated ARH + AWE Touring + Magnaflow Center X + E85 + MSD Coils + Banks iDash + JMS Booster + Synergy Fender Tank ALL the RED Rear End BMR Goodies + JRE Terminator Cam Package + Remote Tuning and Moral Support from TED @ JRE BMR Motor Mounts + DMS Front HX + FIC 30's + APEX SM.10's + 305/345 R888R's = 770rwhp 785rwtq @E50 13.5psi |
12-07-2022, 07:51 AM | #115 |
Yep, I got the wires from them as well. Instead of the MSD wires I went with their premium racing wires. I couldn't fine a relocation bracket listed to fit our cars, but the tech told me to order the LT Gen V "KAT-A7088 Coil Relocation Kit" which I did. I already have protector boots so I'll just be reusing those on the setup.
I'm also having a Mishimoto Aluminum Overflow tank & DSX Flex Fuel kit go in as well with this portion of my build. After this, it will likely sit in the garage until spring I will absolutely share pics & dyno graph when completed. Thanks again for all your help.
12-13-2022, 04:16 PM | #116 |
SoCal.... LOL, I swear these are my last questions....
I received my valve covers, coils, relocation kit and plug wires. A couple questions. 1.) KaTech instructions state to cut off the harness tabs from the SuperCharger, did you do that? and did you have to do both and how? 2.) The relocation kit bracket, does it mount with the logo facing the Valve cover or way from the valve cover? Looks like it can mount either way? 3.) KaTech sent me the Longer wires to fit their relocation kit, but the ends on the wires are both at an angle, my current wires on mine are straight fit to the plugs and only angled on the coil side. Will these fit onto the plugs with an angled end on the plug side? Thanks again and sorry for all the questions.
12-13-2022, 05:24 PM | #117 | |
Hey buddy... no worries. Feedback below 1. Yes, i cut them off using my cordless grinder with an abrasive cut off wheel. Could also use a small reciprocating saw. 2. the logo would mount facing up. See attached photos. 3. My MSD cables were straight on the plug end and perhaps a 30 degree angle on the coil end. See attached. Hope this helps.
12-13-2022, 07:47 PM | #118 | |
12-13-2022, 08:26 PM | #119 | |
That made my night, thank you!!! It has been such a fun project so far...
01-02-2023, 09:41 PM | #120 |
A few sneak peak photos, of some new rubber that was just wrapped around my new Apex SM.10 wheels... I'll share some updated photos and driving impressions once they are mounted
Stay tuned! Oh, and YES, those are 345's out back...
01-03-2023, 09:32 AM | #121 | ||
Drives: HBM ZLE Join Date: Aug 2017
https://www.camaro6.com/forums/showthread.php?t=485975 Last edited by Evansa22; 01-03-2023 at 09:45 AM. |
01-03-2023, 09:46 AM | #122 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Nice gonna look MEAN, back view of that wide rubber . Be waiting for the pics .
Enjoy
2023 ZL1 A10 Shadow Gray Metallic
01-16-2023, 05:13 PM | #123 |
Just walked through this build. Awesome. Ugh need to do a cam now for sure
01-16-2023, 05:49 PM | #124 | ||
Thanks Aaron... I will play close attention to that when they are in.
01-16-2023, 05:50 PM | #125 | |
I could not agree more... Once you have a cammed V8, you will wish you did it years ago
01-28-2023, 02:30 PM | #126 |
Drives: SS 6 speed of course Join Date: Jan 2016
very impressive!
Thread Tools | |
