01-19-2023, 06:48 AM | #99 |
Drives: 2019 Camaro SS 1LE Join Date: Dec 2022
Great job!
It looks similar to my project. My body shop will replace driver side strut tower and Apron on frame machine because it bent up & inwards 2 cm (~1 inch). Unfortunately everything is quite expensive here in Germany and all parts has to be imported from USA. It was good to see that the strut tower rivet direction is from aluminum to steel because this information is missing in the GM repair manual. Logically, rivet direction is from the weaker material into the stronger material. Which glue/silicone/foam did you use on the plenum panel (large black panel mounted on the firewall)? My was glued with some kind of foam but I can not find any information in GM repair manual which kind of. Oliver |
01-19-2023, 04:13 PM | #100 |
America FVCK Yeah!
Drives: 2021 ZL1 1LE A10 Join Date: Mar 2013
A real man builds his ZLE from scratch! Serious respect for you taking this on.
1997 Z28 Anniversary Edition SOLD
2004 GTO ORDER CANCELLED 2004 CTS-V SOLD 2005 CTS-V SOLD 2006 300C SRT-8 SOLD 2006 300C SRT-8 SOLD 2010 CTS-V SOLD 2012 CTS-V coupe SOLD 2013 ZL1 vert SOLD 2016 Callaway Z06 SOLD 2019 Z06 SOLD "I lived my life by one motto.......mottos are for losers" cvp33 |
01-27-2023, 06:12 PM | #101 | |
Drives: 18 ZLE, 18 SS1LE, 16 SS, 23 ZL1 Join Date: Jan 2021
Took it to the dealer to have the new ECU flashed. Had a litany of codes to deal with, and was unable to complete the crankshaft position learn sensor part of the process because of some of the codes. I knew I would get codes from not having rear O2 sensors, and I also had a code for the MAP sensor which I have not located yet. At least the car is running and can move under its own power |
01-27-2023, 06:27 PM | #102 |
Here’s a short clip my son made when I brought it back home:
https://youtu.be/SKipGRKaf-E Oil pressure is above 40 PSI, sounds to me like there’s definitely a cam in it. |
01-27-2023, 08:05 PM | #103 |
Drives: blue velvet Join Date: Jul 2018
sounds insane! any idea what cam is installed?
01-27-2023, 10:31 PM | #104 |
Drives: 2023 ZL1 A10 Join Date: Nov 2021
Hey Neighbor, I'm no help other than moral support, amsoulity great progress, did the tech give you any insite , on what to do so they can complete the flash.
2023 ZL1 A10 Shadow Gray Metallic
01-27-2023, 10:49 PM | #105 | |
Drives: 2019 ZL1 1LE Join Date: Feb 2017
Old: 2017 SS 1LE
Old: 2017 ZL1 Current: 2019 ZL1 1LE |
01-28-2023, 12:32 AM | #106 |
No idea, tried to contact the previous owner by mail after I found papers with his info in the car but never heard back. With the mods that were done I’m hoping they were informed enough to change the oil pump while they were in there. Can’t wait to get the 3” Borla S-type on it!
01-28-2023, 12:33 AM | #107 |
01-28-2023, 12:34 AM | #108 |
Thanks! More progress tonight. I was debating on leaving the hood white but after seeing it with all of the satin black pieces up front I think I’m going to wrap it. Might go with the 3M satin black instead of the OEM wrap.
01-28-2023, 11:37 PM | #109 |
Drives: 2021 Crush ZLE Join Date: Mar 2009
Awesome, just awesome! Love the fact that you are bringing back from the brink of the crusher.
Former GM Norwood Employee
2021 Crush ZLE 6spd 1-19-21 1100 1-27-21 3400 TPW 2-8-21 2-04-21 3800 Built 2-26-21. 4300 3-08-21 Delivered |
01-29-2023, 07:37 AM | #110 |
It was a long slug of hard work and your almost there. Congrats
01-29-2023, 09:24 AM | #111 |
Glad to here , will look very nice to add the Satin black wrap to the hood and low or no glare , when your son is racing. Again please keep me posted, I'll come out.
01-29-2023, 03:06 PM | #112 |
Thanks everyone. Got it to my garage condo where I have a lift to finish it out. Changed the oil, trans fluid and diff fluid and getting ready to do the exhaust.
I have to say I love the trailer I picked up a few weeks ago, so easy to load and unload. Last edited by Sephx1; 01-29-2023 at 03:21 PM. |
