11-10-2018, 08:41 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
ZL1 Addons Bolt on Lift Pads Question
Thinking about getting these - is there any concern about the bolts digging into the side of the pinch weld and maybe creating a area susceptible to rust?
11-10-2018, 02:46 PM | #2 |
Drives: 2017 Camaro FIFTY 2SS Join Date: Jan 2017
I would not be very concerned about that, actually I'd be more concerned about the paint coming off in the areas that contact the jack if you don't use the pads. I have them on my car and they were a great investment
11-10-2018, 03:08 PM | #3 |
Thank you Al Oppenheiser!
11-10-2018, 03:14 PM | #4 |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
This has been discussed and most are using anything from silicone sealant to wet undercoat when installing. Do yourself a favor and use a jack or cribbing to hold it in place while you tighten the set screws. There are two forward lift points and one rear. I installed the pads on the ones closest to the wheels and that allows you to use the rearmost front one to lift the car with a removable ZL1 lift point, the chassis is so rigid both wheels will come off the ground and you can get jack stands under the hard mounts in one shot.
11-10-2018, 03:38 PM | #5 |
I just picked up a single magnetic one with the puck so I can just use the jack location toward the middle and raise both tires and not leave the jack pads bolted to the car.
11-10-2018, 04:51 PM | #6 |
I've lifted my car with a jack and jackstands before; I'm thinking about getting a Quickjack, so wondering about using the bolt-ons vs just using a regular magnetic adapter/puck at each of the 4 lift points. The more I think about maybe the latter would be at least as easy.
11-10-2018, 05:10 PM | #7 | |
11-10-2018, 08:15 PM | #8 |
Drives: 18 Camaro 2SS, 07 Saturn Ion Join Date: Apr 2018
Don't wait for them to get the hint, tell the service advisor up front. I've had mine to a tire shop and a dealership and both made a note of it. Tire shop advisor wrote on the work order in huge letters "Lift on red jack point only".
Ordered from Becky D __ 2018 2SS Silver Ice Redline 6MN, NPP, MRC, GM CAI
11-10-2018, 08:30 PM | #9 | |
Camaros Of Northwest Ohio
Bill
2023 2SS 1LE Red Hot
2016 2SS Black / Black & Arenaline Red (sold) 2023 GMC Canyon Denali 2013 2SS / RS - AGM / Jet Black (sold) 1970 1/2 Z/28 Classic Copper / Tan (sold many years ago) |
11-10-2018, 11:20 PM | #10 |
At least they took care of it!
11-10-2018, 11:27 PM | #11 |
Drives: 2018 Hyper Blue 2SS convertible Join Date: Aug 2017
Anyone worry about the screws coming loose while driving and having it fall off and destroy a tire?
2018 HBM 2SS CONVERTIBLE A8 |
11-10-2018, 11:57 PM | #12 |
I checked them to see if they loosened at all and they were still tight. Haven't worried about them since.
11-11-2018, 04:06 AM | #13 |
i used blue loctite and slathered the pinch weld in never seize. not a problem in almost 2 years and 9000 miles.
11-11-2018, 05:10 AM | #14 |
Drives: 2018 1SS Camaro Join Date: Aug 2018
I went to Lowe's and bought some 3/4 inch wide by 1/8 in thick aluminum and cut two pieces the same length as the pads. I put them between the pinch weld and the screws so the screws would dig into them instead of the pinch weld.
