Old 03-31-2020, 07:58 AM   #15
Dvs510
Dvs510's Avatar
Drives: 2018 Camaro SS/1LE
Originally Posted by gchu View Post
Anyone use this tailpipe cutter from Amazon? Seems like it was hit or miss from the reviews cutting SS exhaust pipes
OEMTOOLS 27045 Tailpipe Cutter
I do like DVS510's suggestion of using hose clamps to help keep the cut straight... I have a blade that is long enough to cut all the way through the pipe (had to cut off the X-Pipe of the NPP muffler I bought ). How high did you lift it with the pavers?
It went through fine - except at the end the final cut it got stuck when the muffler shifted. Fortunately my son was out there to shift the weight so I could finish
I made a ramp with them.. put one behind each back wheel then 2 stacked behind those and then 3 stacked.. lifted the car higher then jack stands would
Dvs510 is offline   Reply With Quote
Old 03-31-2020, 10:01 AM   #16
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
For whatever reason, Borla's cutting distance seemed to be to long.I cut another inch off what they gave, could use another inch off in my opinion. Good idea with the clamp as a guide.
ssmofo is offline   Reply With Quote
