11-14-2019, 12:33 PM | #1 |
Drives: 2017 Camaro ZL1 Join Date: Nov 2019
ZL1 Differential fluid change.
I couldt really find a good video on changing the rear end / differential lube in my 2017 ZL1, so I made one. Pretty straightforward and simple but you would be surprised at the people that think its not that easy. Hopefully this video can help someone out or show them something they might not have known.
Side note: At roughly 28 bucks a quart Chevy is very proud of this fluid, but i was worried about going aftermarket with this particular fluid because of the ELSD in this car. Video - https://youtu.be/NOspYb7GBTM
2017 ZL1 M6
Youtuber - https://www.youtube.com/c/projectzl1 |
11-14-2019, 01:09 PM | #2 |
Drives: 2018 ZL1 Garnet Red A10 Join Date: Mar 2015
Its $23 a quart on Amazon. Yep, its almost stupid simple to do. Good job on the vid.
2018 ZL1 Red Hot A10 (SOLD 1/21)
2001 Corvette Z06 Quicksilver Heads/Cam/Longtubes 443rwhp (SOLD 5/23) 2018 ZL1 Garnet Red A10 (BOUGHT 2/23) |
11-14-2019, 01:15 PM | #3 | |
Thanks for the kind words man, I try to make them to explain stuff out so anyone can do it watching my videos.
2017 ZL1 M6
11-14-2019, 02:01 PM | #4 |
Thank you Al Oppenheiser!
Good idea to flush out a bit of the sludge with the extra...
11-14-2019, 04:28 PM | #5 |
Thank you sir, i even do that with an oil change.
2017 ZL1 M6
11-14-2019, 05:09 PM | #6 |
I've added this video with credit to the oil and diff sticky thread. If you don't mind, I will leave it there. Nice video.
11-14-2019, 05:32 PM | #7 |
Drives: 2019 ZL1 Join Date: Oct 2019
Heck if the diff oil was cheaper, due to flush n fill, and then rinse and repeat again in 100 miles to get it all out I say lol.
11-14-2019, 05:59 PM | #8 |
TEXIT
Drives: 2019 ZL1 M6 Join Date: Aug 2018
Nice vid. I'll be doing this procedure very soon with some Royal Purple diff fluid instead of the over priced AC delco.
11-14-2019, 06:00 PM | #9 |
i don't mind at all. Thanks!
2017 ZL1 M6
11-14-2019, 06:03 PM | #10 | |
i usually use Amsoil fluids but was afraid to do that with this car because of the ELSD. I did not know if the fluid was specific or not..
2017 ZL1 M6
11-14-2019, 06:49 PM | #11 |
The eLSD requires a critical additive that is present in the OEM fluid. It's likely this additive that contributes to the higher price of the fluid; this isn't standard gear oil. I know people have purchased an additive on its own and attempted to add it but then there have been cases where it doesn't meld or mix properly. Isn't the extra $10, $20 or even $30 worth it for the peace of mind?
11-14-2019, 07:09 PM | #12 |
Drives: 2018 ZL1 A10 Join Date: Sep 2014
I always appreciate a good DIY video. Thanks for contributing to the community.
SOLD! 9/1/2020 2018 ZL1 A10 Hyper Blue - Rotofab CAI, Gibson catback
@SurefireDetail OEM ZLE tails/third brake light, Gen5DIY reverse LEDs, front Amber LEDs, SMG laser LED side markers, SMG smoked reflectors 1994 Trans Am LM7/CPT 4L60E/9" 1987 IROC 2006 Silverado |
11-14-2019, 07:33 PM | #13 | |
Drives: 2018 2SS 1LE Black Join Date: Aug 2018
11-14-2019, 07:42 PM | #14 | |
TEXIT
From Royal Purple: Max Gear 75W-90 is recommended for use in truck and automotive front or rear differentials, manual transmissions and lower gear units of marine engines that specify the use of an API GL-5 or GL-4 fluid. It is non-corrosive to soft yellow metals (brass, bronze, copper, etc.) and synchronizer safe. Specially designed to extend gear and bearing life, Max Gear provides superior corrosion protection over competing conventional and synthetic gear oils. We engineered this ultra-tough, high performance automotive hypoid gear oil to provide maximum protection to heavily loaded gears while maximizing power throughout the drive train. Above all, Max Gear outperforms ordinary gear oils by combining the highest quality synthetic oils with Royal Purple’s proprietary Synerlec® additive technology. As a result, Max Gear makes gears run smoother, quieter, cooler and longer without overhauls. A direct reduction of drag in the drive train has a huge advantage for trucks and other 4-wheel drive vehicles, therefore, better gas mileage. Formulated with a friction modifier additive, therefore no additional additives are necessary. Max Gear is available in the following viscosities: 75W-90, 75W-140, 80W-90, 85W-140 and SAE 90 |
Tags |
zl1 |
