08-14-2018, 03:17 AM | #1 |
Drives: 2017 White 1LT 3.6l Auto Join Date: Aug 2018
How much trouble (realistically) is it to swap out the Intake manifold?
How's it going everyone?
My first post on the forums (though I've been browsing here for long while) My question is rather simplistic; but being a nervous old coot I thought I'd ask for your own opinions. Before I go any further, I will say that I have some experience working on cars. But it's been quite a few years since I've done so. Anywho, I was thinking of springing for the Overkill TB and Manifold set. I'm aware that it's only 11 or so bolts to remove the manifold, including the one for the engine cover (not counting the TB). But what always worries me are all the wiring harnesses and sensors. I feel like between that, and the manifold being plastic, one could easily find themselves in a bad situation. Not sure how finicky these motors are when having their sensors messed with. I miss the simpler days when not every single part of my engine had a hundred wires coming out of it.... So please enlighten me as to your own experiences! Is my assessment overblown? Thanks everyone |
08-14-2018, 06:39 AM | #2 | |
Drives: Overkill Supercharged 2016 CamaroV6 Join Date: Mar 2016
Hyperhawk - 2016 Camaro 2LT RS - First LGX in the 12's and 11's Current record holder 11.0@125
Follow me on Instagram https://www.instagram.com/hyperhawkcamaro/ Youtube https://www.youtube.com/channel/UCHR...-ilSpV3gMQnTuA Supercharged with Overkill Superchargers http://www.v6superchargers.com |
08-14-2018, 06:44 AM | #3 |
https://photos.app.goo.gl/ei1Y868rfjA4DLrU6
Let me know if you can view it just shared right from my google photos
08-14-2018, 07:59 AM | #4 |
Drives: Camaro Join Date: May 2018
Not all that hard once you figure things out. If you swap them over make sure to swap over the little green seals on each intake runner. You’ll probably need a u-joint for the furthest back bolts on the top, and a 10 mm wrench for the two on the back of the manifold. Also keep in mind that the back left bolt (if you’re sitting behind the wheel) on top should be loosened but not taken out of the manifold when pulling it out and should be put back in before you try to seat your new manifold.
08-14-2018, 07:59 PM | #5 |
Drives: 2013 1LT RS Camaro Join Date: Apr 2016
It’s an hour job. I’ve got taking off my LFX mani down to about 20 minutes to take off and 20 to put back on. Now that’s not the LGX, but they are similar.
If your slightly mechanicaly inclined, it shouldn’t be an issue. Leaning into the engine bay is the toughest part. |
08-14-2018, 10:33 PM | #6 |
Drives: 2015 Camaro 1SS Join Date: Dec 2017
Took me about 2 hours. That's including the 10 minutes I spent looking for my U-joint, and 45 minutes it took to cut(multiple times) the intake boot so the intake tube would fit right.
08-14-2018, 11:55 PM | #7 |
Thank you for the replies everyone!
The collective input says I'm way overthinking it hahaha. Dustya that video was indeed very informative, it's much appreciated So is the consensus that i should just fire it up and let her run for 10-15 minutes afterwards? I'm feeling a lot more confident, and looking forward to the upgrade! |
08-15-2018, 05:19 PM | #8 |
08-18-2018, 08:40 AM | #9 |
Big Samoan ina little car
Drives: 2016 camaro Join Date: May 2014
if you have basic common sense and basic hand tools, not hard at all...
legit that's all I used, didn't look up any tutorials, videos, etc... just walked out to the car, and did it.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt "Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant |
08-22-2018, 10:26 AM | #10 |
Drives: 2017 1LS 1LE Join Date: Jul 2017
Just recently installed the JacFab manifold. Thanks, Dustya for the video. It was a lot of help and made the install go much faster than it otherwise would have.
08-22-2018, 11:07 PM | #11 |
Drives: 2019 ZL1 1LE Coming Soon! Join Date: Jun 2018
Not hard. Just as a mod on its own it is hard to justify alone. Normally do with other mods. Like a cam on a v8
Coming in soon- 2019 ZL1 A10
08-24-2018, 10:27 AM | #12 | |
08-26-2018, 12:03 AM | #13 | |
There are no cams for the v6 lgx. All i run are a ported tb, and gm intake. Hell of a increase and response.
08-26-2018, 05:19 AM | #14 |
Polynesian,
A bit off topic, but while you're here...could I ask why you decided to switch to the GMPP intake from the AFE one you used to have? Was it throwing codes, or did you just want to address any potential warranty issues? |
