03-14-2016, 08:55 PM | #1 |
Drives: 2016 Camaro 2SS Join Date: Mar 2016
Heads up display power?
I just picked my car up the HUD worked the whole ride home. I started it in my driveway in the dark now and the HUD is gone? Wondering if there is an on/off button I may have hit while messing with stuff.
03-14-2016, 09:02 PM | #2 |
Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
there's intensity dial on dash left of stering wheel....probably the on/off discriminator switch too.
03-14-2016, 09:11 PM | #3 |
Drives: 2010 Tundra Join Date: Aug 2015
Try moving the HUD positioning, up or down. I've had the HUD disappear on me, only to find out it was set to the bottom most position.
03-14-2016, 09:22 PM | #4 |
thanks guys ill check it out in the AM appreciate the response
03-15-2016, 01:16 AM | #5 |
Drives: 2022 Satin Steel ZL1 M6 Join Date: Sep 2015
My entire dash had to come up to fix a bent connection that was causing my HUD to be "off". Hope it isn't that.
03-15-2016, 07:53 AM | #6 |
Drives: 2011 Camaro SS Join Date: Apr 2013
I've seen at least 2-3 people on these forums report a dead HUD as one of the more rare but possible defects on the 2016 Camaro. See:
http://www.camaro6.com/forums/showthread.php?t=434377 http://www.camaro5.com/forums/showthread.php?t=296162 http://www.camaro5.com/forums/showthread.php?t=212491 One person said it just required resetting the computers via battery disconnect, but two people had their dealerships confirm the HUD had actually failed under warranty. Good luck. |
03-15-2016, 08:51 AM | #7 |
Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
Same thing happened to me. Found out the brightness was just turned all of the way down.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 |
03-15-2016, 10:13 AM | #8 |
63 falcon you nailed it the damn brightness was all the way down lol. Thanks again everyone
03-15-2016, 10:15 AM | #9 |
Glad to help!
