11-09-2019, 09:50 AM | #2017 |
Drives: '16 2SS / '05 SRT10 Ram / '65 bu Join Date: Dec 2015
Thanks. Everything has kinda moved to Facebook so I really only posted for the guys that aren't on there.
The scales have been broke all year at Atco so I can only guess what my RW was, I still daily drive the car so only reasonable items were removed.
11-09-2019, 10:10 AM | #2018 |
Pretty impressive for sure. Winter is here in the Midwest so we are done and I have a few things to do over the winter. Just really can't drop any lbs on mine as its 3890 with the cage, front passenger and rear seat removed which was a wash for the chromoly cage. My new blower is about 22 heavier then my old 2300 so just stuck at this weight.
11-09-2019, 07:24 PM | #2019 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Trans: A10
Tires used on the pass: front stock, rear Hoosier 315/35/17 DR2 Performance Mods (if any): Drag Radials Category submitted for: 8 Bolt On ZL1 R/T............ .5881 60'............. 1.6554 330'........... 4.6428 660'........... 7.0586 660’ mph... 103.02 1000'.......... None 1320'.......... 10.8641 1320’ mph… 126.40 Name of the track: London Dragway Date of pass: 11/9/2019 Weather conditions: Include Density Altitude if known. (Optional not required) +26 Car was driven to the track and made back to back passes, this being the 2nd pass. First pass was about .5 mph faster but had an 11.92 ET. Made 3 more passes with a cooler supercharger, but with +711 to +796 DA they were 10.90 and 10.91, with one only reading the 1/8. Another note is the 1/4 trap speed reads slow at this track. About 3.5 mph. The 1/8 always seems to match my PDR and other tracks. The PDR was showing a 27mph gain on the big end for this run, so the true trap speed should be right at 130.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! Last edited by 17CamaroZL1; 11-09-2019 at 07:40 PM. |
11-10-2019, 07:48 AM | #2020 | |
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
11-10-2019, 08:45 AM | #2021 | |
I had a 1.64 60 on one of the passes. I think that's about the best we can do. It's a tricky line you have to balance in order to get the best results with TM. You still have to roll into the throttle very quickly. If you are too fast, your 60 will suffer. Likewise, if you're too slow, it suffers. The crazy thing is, big Dave has gotten some 1.66 and 1.67 60s on the street tires! I've gotten a 1.69 on them. So a tire doesn't really improve the capability of the car. They just make it easier to consistently get good 60s. Here's my theory on TM. It is always at play, not fully opening the throttle body until the car has hit a certain speed. I've seen where someone said it does this in 1st and 2nd gears. Maybe they've seen this in some data logs. Anyway, I think as long as you don't get too aggressive, like trying to mat it off idle, which would spike the torque load, TM will continue opening the TB. If you cross that line, then I feel TM closes the TB for a split second and then starts opening it back up, thus a slower 60 any time I've tried matting it off the line.
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
11-10-2019, 01:22 PM | #2022 | |
In The Circle
Drives: 2010 Camaro 2SSRS IOM M6 Join Date: May 2009
11-10-2019, 05:20 PM | #2023 |
Drives: 2017 Camaro SS Join Date: Apr 2017
Please update
2017 1SS A8 Tires used on pass: DR 275-60-15 Mickey Pros Performance parts: Magnuson, 70mm pulley, CAI, 2" LT, Exhaust, DR, Cam, Pistons, Converter, 95mm TB, Lt4 high and injectors, dsx aux pump, E46 Category summoned for: #5 Power adder stock displacement R/T 1.23 60' 1.49 330 4.223 1/8 6.468 MPH 110.92 ET 10.033 MPH 138.12 Track: Fayetteville Dragway 11/10/19 DA 168 Race Weight 3918 |
11-10-2019, 06:12 PM | #2024 |
Car: 2017 ZL1
Trans: A10 Tires used on the pass: Drag Pack W/ Skinnies (Mickey Thompson ET Street R) Performance Mods (if any): Cam/ LTs/ Ported Blower/ Pulley Combo 2.31 & 9.1/ CAI/ 103TB/ DSX Low Side/ E55 Category submitted for: 9 #2 spot R/T............ 1.146 60'............. 1.459 330'........... 4.094 660'........... 6.244 660’ mph... 114.33 1000'.......... 8.107 1320'.......... 9.684 1320’ mph… 143.69 Name of the track: Atco, NJ Date of pass: 11/4/2019 Weather conditions: Include Density Altitude if known. Car has full interior, no weight reduction
2017 ZL1 A10: 8.84 @ 156 PB
2017 ZL1 A10: Previously FBO 756/761 (9.6 @ 143 1/4) SOLD-2013 ZL1 M6:BTR,LTs,IDs,ATI,RotoFab10.84@129 SOLD-2011 SS M6: Blower, Cam, Alky, LTs. |
11-10-2019, 07:47 PM | #2025 |
Great job Murph. Little 2300 is making some hay.
11-10-2019, 08:36 PM | #2026 |
11-11-2019, 06:24 AM | #2027 |
Just work on the launch and get that in the low .40s or high .30s and you'll be stellar. My best pass was 9.83@141 with similar mods. You'll get there.
11-11-2019, 12:34 PM | #2028 |
In The Circle
Updated!
11-16-2019, 09:22 AM | #2029 |
BAMF SS
Tires used on the pass: 28x10.5x15 M/T PBR
Performance Mods (if any): P1X, FBO, Converter, Gears, Drag pack, W/R, and meth Category submitted for: category #5 R/T..........3.770 60'.............1.380 330'........... 3.965 660'...........6.122 660’ mph... 113.91 1000'.......... 7.992 1320'.......... 9.572 1320’ mph… 140.91 Name of the track: Maryland International Raceway Date of pass:Nov 15, 2019 Weather conditions: -579 DA
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
11-16-2019, 11:10 AM | #2030 |
Nice pass Dan, man that was some great air and making some power. We never get that kind of air here in the Midwest when the tracks are open. The track was opened last weekend but it was for street tires and limited prep and the air was great but not for my power level with shitty prep so I stayed home. Congrats to you and Brett for getting that baby down to those wicked times.
