Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro Issues / Problems | Warranty Discussions | TSB and Recalls
Old 10-06-2013, 09:48 AM   #1
Dznts
Anabolic Connoisseur
Dznts's Avatar
Drives: Sold - Blown Camaro 2SS/RS LS3
AC off due to high engine temp.
Just looking for any input on this. I have searched several threads and still unclear on the cause. Thanks in advance.
Dznts is offline   Reply With Quote
Old 10-06-2013, 09:49 AM   #2
Dznts
Dznts's Avatar
Engine temp is sitting on C. But everything else looks fine, coolant levels look good.
Old 10-06-2013, 10:37 AM   #3
Dznts
Dznts's Avatar
Well I disconnected the ECM harness as someone stated in another thread. That did clear the issue and now my temp gauge and oil pressure gauge are reading correctly. I hope it was just a "glitch" and nothing serious. Still looking for any input if anyone has any ideas. Thanks again
Old 10-06-2013, 10:37 AM   #4
SSMickey
SSMickey's Avatar
Drives: 2010 IBM 2SS
Have you flashed the PCM recently? This is a common problem when using HP Tuners. Remedy is to wait 10-15 minutes after the flash to start the car. I believe it only applies to 2010s though.
ProCharger P1X, Vengeance Racing Kaotic Cam, ARH Headers and Exhaust with Borla ATAK mufflers, MGW Shifter, MTI Drop Springs, Forgeline RB3C Wheels, 3.91 gears, Night Owl LED Control System
SSMickey is offline   Reply With Quote
Old 10-06-2013, 10:44 AM   #5
Dznts
Dznts's Avatar
i havent. ADM did all of my tuning a few months ago
Old 10-06-2013, 10:55 AM   #6
SSMickey
SSMickey's Avatar
Hopefully just a glitch then. I have heard of this happening a few times, but never had to deal with it other than when flashing my PCM, and that was an easy fix, so I'm out of ideas. Sorry.
Old 10-06-2013, 10:57 AM   #7
Dznts
Dznts's Avatar
hey, i do appreciate the input! i hope it was just a glitch. I have also read that it could be a coolant temp sensor, or possibly the thermostat.
Old 10-06-2013, 06:57 PM   #8
ddck24
ddck24's Avatar
Drives: 2012 Camaro 2ss 45th M6
Happened to me.. Luckily was just low coolant level in the overflow tank on the passenger side of radiator
ddck24 is offline   Reply With Quote
Old 10-06-2013, 07:39 PM   #9
LStick
Drives: 2021 Shadow Gray 1LS
Got that code on my 08 Silverado one night driving home from work.
Told me A/C was off due to high temp. Which was odd, since the truck was A/C delete.
LStick is offline   Reply With Quote
Old 10-06-2013, 10:32 PM   #10
Dznts
Dznts's Avatar
Spoke with my tuner, and was told that it was just a glitch. So hopefully all is well. Thanks for the input!
Old 05-11-2017, 07:50 PM   #11
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
Andy got you this far, stay with him.
JusticePete is offline   Reply With Quote
Old 05-11-2017, 09:46 PM   #12
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Did the CEL illuminate? If so, did you pull a code? Was it a P0216 by any chance?
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
