05-17-2010, 01:01 PM | #15 | ||
Drives: 2010 1LT RS Rally Yellow Join Date: Oct 2009
Subs are designed for the lows, as in 80hz and down. Okay, daily driving, 100 hz and down, but to play anything higher, you go to the mids. Quote:
Wrong. two 10 inch subs have 157 square inches of surface area, a single 12 has 113 square inches. Yes, the two tens have more output potential, based on cone area. That is at the cost of weight due to more sub and more then likely a larger box, so less trunk. Maybe even having to add a larger amp. Size of the cone doesn't determine how fast a sub hits. Cone weight, suspension materials and geometry and enclosure all determine which sub will hit the "fastest". Not too mention the amps damping factor, or ability to control the cone's movement, will play a big role in that. In the end, a properly setup single sub setup would be just as impressive, if not more so, then a dual sub setup. Will offer similar, if not better sq, and probably at a cheaper price.
PacMan
05-17-2010, 01:16 PM | #16 | |
Drives: 2010 Camaro 2SS M6 Join Date: Jan 2010
05-17-2010, 01:25 PM | #17 | |
WinISD, while nice, isn't set in stone, nor 100% accurate. Why? It doesn't account for the vehicle, and almost no box modeling software does. I have BassBx Pro6, which does, IF you want to go out and measure your vehicle's response for a given number of frequencies. Of course, you have have to have an enclosure in there roughly the size of the one you might be building. Guess what happens if the box doesn't turn out as big, or turns out bigger? Yep, all that modeling goes to pot, it changes with everything in the car. Hell, flipping down a sunvisor will affect the vehicle's resonant response and frequency, not too mention adding or taking away from the output!! Again, what happens on paper, or computer modeling software, can pretty much be tossed out the window. It'll get you in the ballpark, but not hit the ball, lol.
PacMan
05-17-2010, 01:59 PM | #18 |
Rhymin and Stealin
ok... gonna toss in my 3 pennies on this.
mrray has it pretty much nailed reguarding Software. So, here is what most of us in the industry have learned and know. pick the sub you want. (and just because it says JL does not mean it is the greatest thing since slided bread) then either build and enclosure or have on built to the specs recommended by the manufatcturer. (or if you have a skilled fabricator he can make a few tweaks that will generally help the performance.) run close to the recommended power and tune it properly. and ENJOY. There are so many variables in car audio it will boggle the mind. If you are just looking for average performance, stick to the basics and keep it simple. ponder this as well.... just because everyone knows a brand name does not mean it is the best. and the most expensive will not all ways be the best for your application.
Bryan
I Make Cars Sound Good. Enchantment Editions Arc Audio Competition Team Image Dynamics Elite Sound Performance Team Team Stinger |
05-17-2010, 02:16 PM | #19 |
My 2 12's rock....and BOOM.......
I also used FatMat for the entire trunk, no rattle at all except my Ipass on my front windshield at 20 on the volume and higher......... All with the stock head unit and 200.oo speaker box w/2-12's installed delivered.....
Come see me at www.chicago5thgen.com TEAM LLT, , 2011 Covertible 1LT RS, JDM Color Shift Halo's, Showstopper Camaro Bowtie Led Mirrors, Side Markers and Engine Cover, Pace Setter Catback Exhaust, BK Coilover Kit, 21" Full Crome GM wheels, Tinted windows, I WIN BEARS Plate. Full amber ABL dash and door update with IOM interior panels.
05-17-2010, 05:39 PM | #20 |
Drives: Camaro LS Join Date: Apr 2010
Love the ported box! They always sound the best IMO.
I can't wait to see if my 2x10 ported box will fit through the trunk lid opening. |
05-17-2010, 06:04 PM | #21 |
Drives: 2016 2SS, SW Join Date: Oct 2009
A single 10" is more than sufficient to fill out the bottom.
05-18-2010, 02:03 AM | #22 | ||
He has a 4th order Bandpass, not a standard ported enclosure. I leave my opinion of it out, as Orange5thGen is happy with it, and that's all that matters!
PacMan
05-18-2010, 08:51 AM | #23 |
Drives: White Camaro 2SS/RS Join Date: Aug 2009
d-ball2ss do u have pics cause im thinking about putting two solobaric L5's in my trunk , i wanted to see what it looked like
05-18-2010, 09:24 PM | #24 |
Groverat
Drives: 2010 Camaro Join Date: Jan 2010
I have 2 T5-10 sound stream subs ,with a 2000 watt sound stream amp it just pounds the sh*t out of the car !!
05-18-2010, 10:05 PM | #25 |
Drives: 2010 SS2, 03 vette supercharged, Join Date: Feb 2010
18in ultra
06-29-2010, 09:44 AM | #26 | |
Drives: 2011 CGM 2LT w/RS Join Date: Jun 2010
thanks |
06-29-2010, 10:13 AM | #27 |
How about Two 12's?
06-29-2010, 10:35 AM | #28 |
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Black SS with 1 inch drop coils Installed! Looks & handles Awesome! | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 6 | 05-16-2010 10:05 PM |
Silver SS with 1 inch drop coils Installed! Looks & handles Awesome! | Info@PeddersUSA.com | Suspension / Brakes / Chassis | 3 | 05-15-2010 02:42 PM |
Do you have to run a 2.5 inch axleback with the ARH headers and x-pipe? | g-townmach | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 12 | 02-09-2010 11:00 AM |
21 inch rims - learned a lesson today. | 2032Ceta | Wheels and Tires Talk Sponsored by The Tire Rack | 11 | 09-23-2009 09:29 PM |
