02-20-2020, 02:03 PM | #1 |
Drives: 2018 camaro ss 1le Join Date: Feb 2019
Replace zle canards
My canards got cracked on my car and im gonna be installing a new oem one and was wondering how to install it
02-20-2020, 02:30 PM | #2 |
Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
they are held on with 6 push clips. Although I cant confirm, some folks say if you remove the wheel well liner, you can get to the clips, without having to take the bumper off. I would suspect small hands and a long reach, might be an advantage!
02-20-2020, 04:21 PM | #3 |
Drives: 2018 ZL1 1LE Join Date: Feb 2020
I was able to take the wheel off and access the area through the wheel liner. I had 2 of those white clips holding it where the intake up front was and 4 going up the side. The first 2 you can sort of reach through the intake, the others you have to get through the wheel well. I used a small screwdriver to compress the clip and wiggled them out. Not hard to do, just be patient doing it.
02-21-2020, 06:55 AM | #4 |
@zle_blackwing
Drives: 2018 ZL1 1LE Join Date: Mar 2017
I didn’t find it necessary to remove the wheel, just turn it. A couple of screws holding the liner in and pop the side marker light out. I remember it as 2 thru the wheel liner and 4 thru the intake opening on top of the canard.
