02-17-2020, 02:40 PM | #15 | |
Drives: 6th Gen NicKey Camaro & others. Join Date: Nov 2015
NicKey Stage I Kit; Magnuson TVS2650 Rotofab Big Gulp 5" CAI ARH 2" primary full off road exhaust (no cats) 160 degree thermostat 85mm grip tech pulley Tune We are at the safe limits on 93 pump as well as the 1/2 race gas mix. We drove our car to the track on 93 pump 1/2 tank, filled it up with race gas, so it had almost a full tank. Swapped in the race gas tune, put a rear drag pack/slicks on and broke into the 9s, then swapped back to stock tires and tune and drove home. Reminded me of the old days, but had to manually adjust timing for race gas back then. Last edited by Stefano; 02-17-2020 at 03:02 PM. |
02-17-2020, 05:02 PM | #16 |
Nice
02-17-2020, 05:35 PM | #17 | |
Drives: 2017 ZL1 A10 & 2021 BMW M340i x Dr Join Date: Mar 2009
Sold 1967 Camaro Pro Street. Ran 10's mild BB on NOS. 2017 HyperBlue ZL1 A10 ** Born 3/17/17**Delivered 4/08/17 2020 Build: Mag2650, BTR Stage2, NW103, BG, 14% lower, 90mm upper, ARH 2" Long system w/no cats, SW Legend mufflers. **807hp/762tq on 93 gas** and **848hp/792tq on e47** Sold 2018 (Go Mango) Dodge Charger Daytona 392 Daily Driver Daily Driver 2021 BMW M340i Xdrive |
02-17-2020, 09:27 PM | #18 |
We have not made any passes on the ZLE with 93 pump, although we will be running a regular ZL1 with this same option package at Bradenton for the Chevy street car challenge 10 sec class bracket.
02-18-2020, 05:16 AM | #19 |
Maybe I will see you there. That is my home track. I raced that event a few years ago with my 67.
02-18-2020, 06:40 AM | #20 |
Drives: 2017 ZL1 Join Date: Jul 2017
02-18-2020, 06:50 AM | #21 |
Thanks for the reply, I will check them out.
02-18-2020, 07:09 AM | #22 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
I’m thinking that with the 2650, cam, and low side should make 850whp on pump.
02-18-2020, 07:24 AM | #23 |
If you are right, that would be great. My goals with same parts are only 750whp on 93, so anything more without the big expense of injectors would be perfect.
02-18-2020, 08:27 AM | #24 | |
On 93 our bolt on Kit is seeing 750hp +/-
02-18-2020, 08:55 AM | #25 |
Those mods are exactly what i had in mind for mine. I think with the addition of a low side pump and cam i will be able to be around 800+whp and 9.7-9.8 1/4 mile times. Not sure i will need to run the 30% injectors based off your results.
thanks for posting it.
02-18-2020, 01:02 PM | #26 |
Drives: 2017 ZL1 Join Date: Mar 2014
02-19-2020, 02:43 PM | #27 |
Drives: 2017 ZL1 Join Date: Jun 2018
Jannetty made 849 on stock fueling with a JMS. If I remember right it was at 16 pounds of boost.
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
02-19-2020, 03:08 PM | #28 |
They had a +30% cam lobe when they made that much on 93. Not sure about the JMS on the low side...
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
Tags |
fuel, fueling, magnuson, tvs2650 |
