09-11-2022, 08:50 PM | #1 |
In car Video of 10.34@135 w/1.50 60 ft pass at FEST
Here is an in car VId of my pass at the Ls fest 2022
https://www.facebook.com/10002269009...45175025849499
09-12-2022, 12:46 PM | #2 | |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
09-12-2022, 02:10 PM | #3 |
Thx and I haven't yet but will on Wednesday and its well above 600. The car weighs over 3900 lbs with the new blower and driver. I think it will make over 650.
09-12-2022, 02:19 PM | #4 | |
Your HP computed from your vehicle ET is 630.75 rear wheel HP and 700.83 flywheel HP. 10.34 Your HP computed from your vehicle MPH is 695.13 rear wheel HP and 772.37 flywheel HP. 135 Your HP computed from your vehicle ET is 659.65 flywheel HP and 593.69 rear wheel HP. 6.70 Your HP computed from your vehicle MPH is 761.82 flywheel HP and 685.63 rear wheel HP. 106
09-12-2022, 02:45 PM | #5 |
Drives: 2023 2SS Convertible Join Date: May 2009
Wow, super smooth. Awesome ride!
-Geoff
09-12-2022, 02:48 PM | #6 |
09-12-2022, 03:17 PM | #7 | |
https://forums.holley.com/forum/holl...si-equivalents
09-12-2022, 03:27 PM | #8 |
What's really cool is Mike will be logged in and able to watch the log as we are doing the pulls instead of me sending the log via Email. Then he can make changes to the Editor without me touching anything. He has control of my lap top, its called Anydesk.com.
09-12-2022, 03:42 PM | #9 |
2Spdsy
Drives: 2021 Camaro LT1 A10 Join Date: Mar 2016
That’s cool man . Did you ever make any other passes?
09-12-2022, 04:19 PM | #10 |
Pretty soon you will have somebody driving the car for ya too.
2016 NFG 1SS A8
09-12-2022, 04:21 PM | #11 |
Yes, both were bad. Spun the tires on the launch both times. We pulled some timing down low for the next pass and it started raining. Then they'd get the track dry and it would rain again so we just gave up. I think my class finally ran again late Saturday night and then came the rain again on Sunday so we came home. So, 1 great pass and 2 spinning not winning passes. I've got a couple of events for next month and we'll have much better weather here in Missouri. Hoping for 60 degrees temps and 500 DA or less, then its going to really haul the mail.
09-12-2022, 04:43 PM | #12 |
Haha another wise ass, I'd be shocked if you didn't make some comment like that, love it. I'm almost 71 so maybe I will someday. Remember last year when we were discussing more timing and less boost, that's where we are at. He looked at Mike Jrs log from his 10.36 pass with the 2650 and they were running about 12.5 lbs of boost and I think he said around 21 degrees of timing on E85. So just a reversal of his car on mine. We'll know more if I can run the 98mm on Wednesday.
09-12-2022, 05:06 PM | #13 |
https://www.facebook.com/watch/?ref=...5&q=toohighpsi
Here is a toohighpsi video that Mike put together. That was my buddies C7 missing shifts, hitting the limiter and you name it and that car did it. He needs a track tune badly. Mike worked on it a little and got some of it fixed and it finally went 10.50s but it has a 2650 and should be running really low 10s, it made 720 on the dyno on E85 but that's all they did and didn't make sure it would shift correctly under power.
09-12-2022, 06:30 PM | #14 | |
You know I was thinking the same thing about Mike Jr car. I didn't know if it was tune or DA but I remember him running a lot more boost with a 2650 and running similar times.
2016 NFG 1SS A8
