06-29-2022, 01:17 PM | #1 |
Radial and rim for 900whp zl1
I currently have 750 whp and have the nitto55r2 on the stock rim and they are working good for me. I mostly do Highway pulls and go to the drag strip 2-4 times a year.
I'm going to get some mods done and I'm going to be in the 850-900 whp range. Is there a radial and rim that would work for highway cruising and the occasional drag strip that won't break my drive line? |
06-29-2022, 04:46 PM | #2 | |
'20 ZL1 1LE A10,
06-29-2022, 04:57 PM | #3 |
06-29-2022, 05:42 PM | #4 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
17” wheel with 305/45/17 ET Street R’s if the main focus is straight line performance. Have to be cautious in the rain, but there’s always a trade off when it comes to tires.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
06-29-2022, 05:46 PM | #5 |
06-29-2022, 07:25 PM | #6 | |
I tried the Mickey Street R's on 17" bead locks, last year and this year. but they wobbled like crazy at high speeds. But others have had good luck with them.
'20 ZL1 1LE A10,
06-29-2022, 09:29 PM | #7 | |
I have the nitto555r2 already . Has anyone tried the Mickey Street R's on 18" rims to reduce wobble? |
06-29-2022, 10:13 PM | #8 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Use the MT Street SS 305/45/17 if you want to drive on the street as well as track, R is just track. Well i mean you can drive the R on the street but its not a good idea
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
06-30-2022, 03:16 AM | #9 |
This is one of the areas that expose those that want to be fast/quick and will do what it takes and those that only think and talk like they want to. If you truly want to use all of the power you’re going to have to get a tire that isn’t great at everything. That’s just how it is. I went 1.32 60’ consistently on a 17” ET Street R with ~900 RWHP. If I knew then what I know now about tuning the 10L90 (along with my tuner), it would have been in the 1.2’s. If you want to make fewer sacrifices on the street but still want ok drag strip performance, get the MT S/S’s. There will never be one tire that does it all great for a RWD car.
06-30-2022, 08:44 AM | #10 | |
I've got: 1. OEM 3R in the garage, which might have one track day left in them. 2. 4S for the inevitable any-kind-of-weather drive I have to make such as to my shop/ dyno. 3. R888R for the strip and the occasional short drive or dig.
'20 ZL1 1LE A10,
06-30-2022, 09:38 AM | #11 |
I bet you’ll want to add another once the new blower is on. :-)
06-30-2022, 10:40 AM | #12 |
Yes, which is why I'm keeping my bead locks.
'20 ZL1 1LE A10,
06-30-2022, 11:49 AM | #13 |
Drives: Turbo 6.2 Join Date: Feb 2019
900 wheel... I'm def with the 17" wheel and et street r for any type of straight line racing. Ive auto crossed with my 17s and Rs. they werent the best but they did work.
As always, there are levels. With 900 wheel hp, your best best is to gave a drag pack and a street setup.
2016 Turbo Camaro SS - 800hp/900tq 9.7@146
2018 LTZ Z71 Redline Silverado - 381hp/420tq 13.8@100 |
07-01-2022, 06:49 PM | #14 |
Ok , I have my made up my mind already with the rear wheel setup. For the fronts should I do a 18x5 rim or a 18x8.5? Keep in mind this is mostly for Highway pulls and a handful of dragstrip events. I will also run the front stock rims but once in a while I would like to use a smaller tire in the front .
