09-06-2020, 03:41 PM | #57 | |
09-06-2020, 05:46 PM | #58 |
Drives: '21 V6 1LE Join Date: Jul 2020
LOL how is this even a discussion? Just because your wheels haven't fallen off doesn't mean they won't. I hope you all continue to have good luck, but why in the hell would GM just make up a random number for the torque spec?
I'm bored/excited waiting for my Camaro to be built so I read the manual, and the 2021 also says 140 lb ft (no call-outs for different trims/models either, just like the image above). |
09-06-2020, 10:14 PM | #59 |
Drives: 2019 ZL1 1LE Camaro A10 Join Date: Jun 2019
140# lug nut torque.
I’ll tell you having also been a racer I was pretty shocked when the manual said 140#’s. The highest I ever torqued the race cars was 115#. I never had a problem. I went ahead and torqued to 140# - what a mistake. It took me standing(jumping)on a 24” cheater to break them loose. Plus killed 6 or 7 of the stock lug nuts. Have since torqued them to 110# and have had zero trouble. Just my two cent’s.
2019 ZL1 1LE
2016 Mustang GT 2014 GT 500 2012 GT 500 2010 Mustang Spec Iron 2003 New Edge w/Coyote Now running in America Iron 2000 New Edge w/ Coyote 2004 Corvette 2002 Corvette |
09-06-2020, 10:22 PM | #60 | |
09-07-2020, 09:59 AM | #61 |
Drives: Chevrolet SS 1LE Join Date: Oct 2019
Holy shit, people! The torque spec isn't open to interpretation! These studs are 14mm, much bigger than what most cars use...probably because these cars are heavy. A Mustang GT has the same M14x1.5 studs, and Ford calls for 150lb/ft. So it's not like Chevy is out on a limb here. A 14mm stud has a well established torque spec, and 140lb/ft is it. The spec is zip to do with any other factor.
Just because you're "a racer" and never used this high a torque spec before doesn't mean you shouldn't now. You probably never had a car with 14mm studs before. If someone is breaking lug nuts on 14mm studs and thinks they torqued it to 140lb, then either their torque wrench is really off or the studs had previous damage of some sort. If you need a long breaker bar have to stand on the end of it to break loose these lug nuts, then you had considerably more than 140lb/ft on them. It's your car and you can do what you want, but please stop advising others to torque their lug nuts to less than the factory spec! That's just irresponsible.
Matt Miller
2020 SS 1LE |
09-07-2020, 11:47 AM | #62 |
Drives: 2020 SS1LE Shadow Gray Metallic Join Date: Feb 2018
My Gt350 was 150ftlbs, I never had an issue taking the wheels on or off. I really don’t see the problem with 140.
09-07-2020, 07:27 PM | #63 | |
Drives: 2018 1SS 1LE & 1973 Datsun 240Z Join Date: Sep 2015
100% agree!!! This is not debatable. Nigel |
09-07-2020, 07:46 PM | #64 | |
Drives: 2018 Camaro 1SS 1LE Join Date: Sep 2018
09-07-2020, 08:00 PM | #65 |
2020 Shadow Gray 2SS
This thread should have been exactly 2 posts long, post 1 someone asking what the lugnut torque is and post 2 an image of the owners manual showing 140 ft/lb...
Done...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
09-07-2020, 08:05 PM | #66 | |
So the entire reason for the bigger studs is to allow greater clamping force between the wheel and hub face. If you decide your car is fine with 100lb/ft because you know better than the engineers, you're choosing to reduce the force holding your wheel in place by 29%.
Matt Miller
2020 SS 1LE |
09-07-2020, 09:08 PM | #67 |
Drives: '16 Garnet Red 1SS Join Date: Mar 2014
Oof, gotta buy a $100 tq wrench just to tighten the lug nuts on the Camaro.
'16 Camaro 1SS
'18 Miata GT Gone: '01 Camaro, '14 Camaro, '90 Miata |
09-07-2020, 09:09 PM | #68 | |
Torque.
2019 ZL1 1LE
09-08-2020, 08:45 AM | #69 | |
But since you want to argue the point, let's dissect your post a little further. You torqued them to 140lb/ft, but you don't have a suitable torque "northern freight" torque wrench, so...how do you know what you torqued them to? For someone wanting to assert his racing credentials, it seems awfully strange that you don't have a cheap torque wrench to tighten your lug nuts properly. It's a little like a mechanic saying it's okay to work underneath your car without jackstands because he can't afford them. By the way, you can buy an adequate torque wrench from Autozone for $47. I don't think it's news to anyone that you need the proper tools if you want to work on your car yourself. But to put this in perspective, a proper oil/filter change on our cars costs around $100 if you do it yourself (just the oil and filter, not including tools). You stated you had to jump on a 24" breaker bar to get them loose at 140lb/ft. So...you only weigh 70lbs? Because that's the force we're talking about at the end of a two-foot lever to reach 140lb/ft. And you ruined the lug nuts doing so? This despite the fact that millions of cars and trucks these days have 14mm studs and similar torque requirements, and other people aren't complaining about similar experiences? A modicum of thought from someone who's touting a road racing resume should tell you those things don't add up. It seems way more likely that your lug nuts were torqued to a force much, much higher than the specified 140lb/ft, or they rusted on, or something like that. Whatever problems you had, they weren't the result of torquing to the factory spec. Stay safe, indeed.
Matt Miller
2020 SS 1LE |
09-08-2020, 04:45 PM | #70 |
Drives: 2018 Hyper Blue 2SS 1LE Join Date: Aug 2018
People do what they want, but there is a reason the spec is 140lbft. It's not out of line either. Ford is 150, Tesla is 135. At least you aren't having to torque my truck wheels, 450-500lbft.
2018 Hyper Blue Metallic 2SS 1LE with Nav, PDR, and track alignment
1:34.20 Willow Springs Big Track |
