09-23-2014, 02:32 PM | #1 |
Drives: 2011 Camaro 2SS Join Date: Sep 2012
"Service Stabiltrak"
Hey guys,
Today when I was doing some driving on a "Private" road, I was flooring it and as I am in 3rd gear, nearing 90-100mph, I get the message "Service Stabiltrak" (Keep in mind I was driving with just T/C off, ST on) once this popped up I backed off the throttle and after a few seconds it went away. Can Acceleration alone set it off? Should I be concerned? I have researched and found too many different answers as to why this message pops up. Maybe a sensor? I have also heard ECU?
2011 Camaro 2SS/RS LS3 M6 - 672rwhp/581rwtq - 91 octane tune
09-24-2014, 09:58 PM | #2 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
There are a lot of things that can lead to that message..unfortunately all you have told us is that you got a "service Stabilitrak" message while flooring it in third gear......if you have searched like you said you have....then you would know that that message can be produced by a lot of things....maybe some more details about your mods and tune would be in order. Or even how it was tuned.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
09-25-2014, 12:19 PM | #3 | |
Start by inspecting plugs and wires, a misfire will make the light flash. Misfire can be caused by weak wires, cracked spark plug, low fuel pressure which caused lean condition. Ted.
www.jannettyracing.com
09-25-2014, 12:20 PM | #4 |
The Stealth Bumblebee
Drives: Black 2013 2LS Join Date: Aug 2013
You completely climb a curb? I did and had that message.
KILLER BEE
09-28-2014, 12:31 PM | #5 |
Drives: 2010 1SS M6 Join Date: Jan 2014
I got this the other day at the track as well. I'll keep you updated
