12-16-2019, 04:17 PM | #1 |
Drives: 2017 50th Camaro SS Join Date: Jul 2016
Advice on Pulley Size
Current Setup:
P1X 7 PSI 4.00" pulley Stock fuel system Stock cam Conservative tune 545 RWHP Mods in January: LT4 HPFP LT4 Injectors Aux low side pump Question: Can I go another pulley size down and if so to what? What would I expect for boost levels? I KNOW every car/system is different. Looking for some general advice. THANKS!
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
12-16-2019, 06:10 PM | #2 |
Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
I ran a 3.7 pulley on that setup plus a JMS Bap with no issues. 10 to 10.5lbs boost.
12-16-2019, 07:02 PM | #3 |
I'm on the 3.9 and it's 8-9 lbs of boost. Thinking about going to the 3.7 to build boost a little quicker.
12-16-2019, 09:21 PM | #4 |
BAMF SS
3.7 pulley. 10-11 psi. Lt4 low, high, injectors. Si Glenn meth nozzle. 760 rwhp
2016 1SS A8: FBO + Circle D + P1X + Meth + Tuned by Pray Performance
Stock Longblock 800 SAE rwhp. 9.4 @ 145 mph. |
12-17-2019, 07:15 AM | #5 | |
The ZL-1 in tank pump and JMS will do a great job at supplying fuel for up to 750 RWHP Other Items I would suggest if you don't have them. DSX Baro Break out harness and sensor. 3 bar map sensor. NGK LTR6IX-11 MSD Wires Kooks Long Tube headers with green cats. Let me know If I can be of assistance in your quest for more power. Ted.
www.jannettyracing.com
06-30-2021, 08:09 AM | #6 |
Drives: firebird Join Date: Jan 2010
If you use a zl1 in tank and high side pump why would you need the JMP BAP?
06-30-2021, 09:20 AM | #7 | |
They are on every car we build for a very good reason, I have talked about it at length, here, on facebook, and other forums. Ted.
06-30-2021, 10:57 AM | #8 |
Drives: 17 SS 1LE Join Date: Feb 2021
Depends on your elevation and what supporting mods you have. Im at 5-5200' running a D1SC 3.7" griptec pulley.. stage 2 intercooler, TSP long tubes and Borla atak "cat" back, MSD intake, NW 103mm throttle body, 91 with AEM meth kit 1000cc nozzle, LT4 fuel system..
Depending on the day im 11-12psi. Made 716whp and 683tq, you should be fine with that setup. Not sure what fuel options you have but we are very limited here in Reno NV and get shitty 91 which is why I added meth on top to help with the octane compensation. It doesn't hurt and is easy to setup in our cars, it would be the only other thing I would suggest to get on there. Im at 15* at WOT with zero knock across the full RPM range. Tuning plays a big role and we are lucky enough to have a pretty solid guy in town |
