11-30-2020, 12:13 PM | #1 |
Drives: C5 Join Date: Nov 2018
Rear end/LSD diff(erences) between LE and base
Just trying to understand what is available in the aftermarket sector..
1LE has an electronically controlled led from the factory. Base SS has a mechanical lsd (worsen or clutch?) Are final drives available for either? Thank you. |
11-30-2020, 12:51 PM | #2 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
11-30-2020, 02:22 PM | #3 |
Drives: 2019 ZL1 1LE Join Date: Sep 2010
The non-electronic LSD is a passive clutch type. The ring gear is welded, rather than bolted, so nobody makes alternate final drives. For the same reason, nobody makes aftermarket racing differentials either.
The eLSD has a bolted ring gear, but nobody makes alternate final drives for these. |
