11-09-2017, 02:44 AM | #1 |
Drives: 2017 Camaro 2ss Join Date: Oct 2017
MSD Intake Manifold and K&N CAI
Just installed these bad boys the other night on my 2017 2SS. Someone on the FB Camaro6 page said something about the KN CAI limiting what my MSD is capable of doing. Is this true?
11-09-2017, 04:15 AM | #2 |
The K&N CAI seems to screw up the MAF. We had a member try one without a tune and it made the car run very rich.
11-09-2017, 05:35 AM | #3 | |
Drives: 2017 Camaro SS 50th Edition Join Date: Jul 2017
I tend to try and bundle when I do a tune or re-tune since they can range from $300-$600. I have to take my car back to RPM to get a torque converter upgrade, so I swapped out the tires and rims, and put on the new CAI to have it all done at once. If you just plan to do the CAI and MSD and want a remote tune I believe RDP Motorsport, and Pray Performance will do those for you. You would just need to purchase the programmer and tell them what upgrades you have done and they will send you a tune to use. It is usually better to take the car in the shop for a tune, but this way will also work depending on how much more you are planning to do. Hope that helps. http://www.rdpmotorsport.com/Default.aspx https://www.facebook.com/prayperformance/ |
11-09-2017, 07:10 AM | #4 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
If you plan on keeping the ECU stock then yes you should ditch the K&N and get a Rotofab. However, if you plan to tune the car to the K&N is not a limiter and you will gain more power with a tune than you would with no tune.
In short. Tune the car. |
11-09-2017, 07:38 AM | #5 |
Drives: 2016 Camaro SS Join Date: Oct 2016
Megahurtz is spot on.
A tune is really the right answer in this situation. |
11-09-2017, 09:09 AM | #6 |
A CAI is a CAI...they all going to be within a couple HP from each other once tuned. The kicker is the Rotofab does not require a tune. Either way you should tune the car and reap the full benefits of that setup.
2016 NFG 1SS A8
11-09-2017, 12:31 PM | #7 |
Drives: 2013 SS Join Date: May 2013
Rotofab FTW
11-09-2017, 02:48 PM | #8 |
Drives: 2016 2SS Join Date: Jul 2016
Agreed. Roto-fab all day every day. At least swap to a non oiled filter.
11-10-2017, 04:08 AM | #9 | |
11-22-2017, 09:25 PM | #10 |
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
JuicedMotorsports beats everyone's prices on the Rotofab and MSD with the forum discount.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
