09-29-2021, 09:24 PM | #127 |
Petro-sexual
I'm probably misunderstanding, but HHP clearly states the TCMs don't come ready-to-run out of the box without confirmation of some basic stuff. Did you follow the directions, verify the tune file you were starting with was appropriate, and then made whatever corrections to the stock file you wanted? These TCMs don't come "tuned" to my understanding. You have to calibrate some engine parameters along with the TCM.
09-29-2021, 09:58 PM | #128 | |
Drives: 2019 ZL1 Join Date: Mar 2019
This has nothing to do with what hes talking about.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
09-29-2021, 09:59 PM | #129 | |
Shift points, Torque Limits, Torque Settings, Line Pressures etc.
09-29-2021, 10:44 PM | #130 | |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
It's probably worth the few hundred dollars if you have a 2017-2018 car. IMO, I don't think it's worth it for the 2019+ cars because you'll be spending over $1500 in the end. Buying the TCM then having a tuner, tune the TCM for you. But to each their own. Just like how you like the 2nd to 3rd shift....thats not how how the A10 was meant to shift. |
09-29-2021, 11:47 PM | #131 |
Drives: Black 2021 ZLE 10AT Join Date: Jan 2017
09-29-2021, 11:51 PM | #132 | |
09-29-2021, 11:54 PM | #133 | |
09-30-2021, 08:08 AM | #134 |
Of course it does:
The OP said: "In manual mode, my ZLE sometimes shifts gracefully into the next gear ... " He's referring to the shifting in his current car. But it won't upshift in manual mode.
'20 ZL1 1LE A10,
09-30-2021, 08:13 AM | #135 |
Petro-sexual
The solution for what it sounds like you're looking for is probably getting a TCM. This will optimize your combination, and likely be worth a few tenths in the 1320 under good track prep and good tires. I would be careful, if you care about corners, that you don't shoot for that kind of shift if you're tracking your car. Shifts that abrupt might upset the car, mid-corner/exit/etc. You know what you want, so you probably already understand that, so IMO, a TCM-tune is the way to go to have it how you want it.
There's balancing from the ECM to the TCM though, from what I'm seeing. HHP charges about $500 to do both from my last contact. But - they also said they're pretty busy at the moment, so they're not taking too much of that kind of work in. I know of other shops charging as much as $1200 for remote tuning. If you do it yourself, and don't already have HPTuners, you'll be looking at about the same to be able to do some tuning, and even get some HPTuners-remote-tuning-guys from that forum to tune your car for you. I've been told about half the shift improvements for the transmission are on the engine side. From what I can see, I believe those people and their statements. My point is, you'll still have some optimization in the TCM though.
09-30-2021, 08:19 AM | #136 |
Yep. Every tuner I've contacted said he would have to tune both the ECM and TCM together. My GTR TCMs were also tuned with the ECM.
'20 ZL1 1LE A10,
09-30-2021, 09:10 AM | #137 | ||
2016 NFG 1SS A8
09-30-2021, 09:13 AM | #138 |
JSH what in the lords name are you talking about. He’s clearly saying it shifts differently sometimes in manual mode (using paddles). ESP From shifts 2-3, he likes the way it shifts and wants all to shift like that.
09-30-2021, 12:40 PM | #139 | |
For me, correcting these and other issues and significantly improving the 60 ft. is worth a few grand. Gotta make it 60 ft. like GM wasn't involved with it.
'20 ZL1 1LE A10,
09-30-2021, 01:04 PM | #140 |
You're not the first to wonder what I'm talking about...
'20 ZL1 1LE A10,
