12-14-2017, 11:23 AM | #1 |
Drives: 2017 Camaro 2SS Join Date: Dec 2016
Phastek Springs and 285/35 - 305/35 tires???
Does anyone know if it can be done? I have the MRR M017 wheels and want to know if I can fit this size tire without any issue?
As a note: I have already moved the wiring harness and don't care if these will wear a small hole in the driver rear well liner. I would rather no more rubbing to occur than that. |
12-14-2017, 12:02 PM | #2 |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
Depends on the offset of the wheels. My lowered ZL1 has 0 rubbing issues.
12-14-2017, 04:30 PM | #3 |
Does your ZL1 have stock tires? The stock sizes are 30 profile rather than 35 profile and what I currently am running with zero rub issues and lowered 1.5" front and rear. I am worried adding additional tire height may cause rubbing.
12-14-2017, 05:04 PM | #4 |
Checked on the ground with the stock wheel and tire setup and there was plenty of space still on the drivers side, even with a 35 tire.
12-14-2017, 05:59 PM | #5 |
Drives: 2017 Summit White 2SS Join Date: Jan 2017
I’m running this setup with only one minor issue not related to rubbing
Follow me on IG: @lip_stick.ss
