12-19-2016, 07:07 PM | #1 |
Drives: 2018 ZL1 Join Date: Sep 2016
Bf goodrich vs nitto
With the procharger on I definitely need to invest in better tires. I have a 10 in rear rim so I'm looking at 285 30 20 in either nitto nt555g2 or bfgoodrich ta kdw. Any input?
12-19-2016, 07:39 PM | #2 |
Drives: 2017 Chevrolet SS 1LE Join Date: Oct 2016
Id go sticker and 285/35/20 brotha
Hankook RS3 are well worth it IMO and or MPSS or Toyo R888 Whats your thoughts there? |
12-19-2016, 07:50 PM | #3 |
Drives: 2016 Camaro 2SS A8 Join Date: Jun 2016
Do not get the NT555G2! I have them in 305/30r20 and have less traction than the stock tires. Ive let air out and tried different things, but the tires wont hold and my care is bone stock.
12-19-2016, 07:58 PM | #4 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
And here we go again...
The 555 is fine for DD and the occasional on-ramp. It will last you FAR longer than the OEM tire with a 320TW rating. The TA KDW is an OLD tire. I would be surprised if the manufacture date was in the last 5-7 years. The current BFG tire in the same category as the 555G2 is the GForce Sport Comp 2. Is dry traction in a straight line your only consideration?
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-19-2016, 08:16 PM | #5 |
12-19-2016, 08:18 PM | #6 | |
12-19-2016, 09:01 PM | #7 | |
Again...what are you looking for? 'Daily' doesn't help much. Fort Polk, LA? Then you may want a aggressive tire that is good in the wet. You won't need to step down to an all-season because your temps don't stay <40F.
2017 HBM SS 1LE
12-19-2016, 09:23 PM | #8 |
SABIO
Price limit?
What is your front tire size? You buying all 4? Might limit choices trying to match proper sizing.
12-19-2016, 11:33 PM | #9 |
Drives: 2016 2ss Join Date: Oct 2016
I would do a 295-35-20 in mpss...make sure you get the 105y k1 Ferrari one though, it has a tread width of 12 inches, the Porsche version has a tread width of like 11.6
12-20-2016, 09:15 AM | #10 |
Drives: 2016 1SS Join Date: Jan 2016
Toyo R888 ??? That's a full track tire. People should not daily drive this tire. Ok to drive to the track and back but not more than that.
1SS, Black, Black Wheels, A8, MRC, NPP
12-20-2016, 11:37 AM | #11 |
Yep the R888 tire its a DOT tire so you can use it on and off the track street usage is common here I've used them in the dry and wet they fair well actually.
12-20-2016, 02:59 PM | #12 |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
Same here...however I would consider stepping up to a wheel that will get you into 305-width tires. Hell I have a basically stock power-level car and I still can make the 305s spin if I hoon it.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
12-20-2016, 04:12 PM | #13 |
