02-14-2018, 08:43 AM | #29 |
Coupe Newbie
Drives: 2017 ZL1, 2021 Corvette Convertible Join Date: Jul 2011
So far I've been very impressed with the PS4Ss. They give a smoother ride with less noise than the GYs. They also seem to heat up a little faster than the GYs. Grip in cold temps seems better as well. I haven't driven them in the rain or ambient temps above the 50s yet. Those will be the next big test.
02-14-2018, 01:43 PM | #30 | ||
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6 Join Date: Sep 2013
It seems like most of you are using or considering Xpel PPF. From what I've read and after viewing some comparisons, it seems to me that the newest 3M Scotchgard Pro (8mm) films stand out in terms of self-healing and scratch/chemical resistance. Last August I did some research on films and coatings so I thought I'd share what I found. A Comparison of New 3M Scotchgard Pro Series, XPEL Ultimate PPF & SunTek PPF A detailed description of Paint Protective Films in general with specific guidance on chemical (nano) coatings with PPFs. Pros and Cons of Clear Bra Paint Protection Film Posted by James Detmer on 03.10.12 Updated 06/13/2017 I can't afford the thousands of $ to get a pro shop to do it at this point so, after watching a few YouTube videos I feel like I could do this myself in a friend's large garage if I took my time. The downside of this is that you don't get the 7-year 3M warranty without a professional installation. However, with an actual life expectancy of at least 7 years and the reviews I've seen I doubt I'd need it. [Installation Demos and Tutorials] This one specifically features the newest 3M film. He uses a bottle of pre-mixed solution of alcohol, distilled water, and baby shampoo. 3M Scotchgard Paint Protection Film Pro Series Installation Demo The next two videos from "Install Proz" show installation of custom cut pieces and a pre-cut kit. I like this one because he gives details about tools and materials you might need. One person in the remarks has done this and suggests using a whetted vinyl shower curtain to create a pattern for areas with curves and irregular shapes. Custom cut from bulk rolls: How To Install Clear Paint Protection Bra Hood and Fender Kit Pre-cut kit: How to Install Computer Cut Paint Protection Film Kit [Bulk Roll and Kit Pricing] I priced out kits and bulk rolls after taking a few measurements on my car. Reading the Amazon reviews offer some additional insights. To cover rocker panels, section just in front of rear wheels, and directly behind rear wheels I figured it would cost less than $250 including film, tools, and materials. These are the areas where I've observed wear and/or damage. You can find several different size rolls but I was unable to find anything wider than 30 inches, not quite wide enough for doors, entire hood insert, or roof. Two of these (1 per side) for 1 rocker panel and 1 flare panel in front of rear wheel $86.75 3M Scotchgard PRO Series Clear Paint Protection Bulk Film Roll 12-by-108-inches Two of these for bottom trim (bumper) behind each wheel: $18.00 12" x 24" Certified Genuine 3M Scotchgard Pro Series Paint Protection Film Bulk Roll Clear Bra Piece This kit might be next. It comes with all the pre-cut pieces for the 2017 ZL1 front facia, hood, mirrors, headlights, etc. I haven't decided whether I'll get this yet. $288.98 Chevrolet Camaro ZL1 2017 3M Scotchgard PRO Series PreCut Paint Protection Film Clear Bra Kit Anyway, just thought I'd share what I found in case it might help others. --Cal |
02-14-2018, 02:23 PM | #31 |
Drives: N/A Join Date: Dec 2014
I just got my ZL1 too, when talking to my coating installer (he does Modesta) said that most people coat the car and xpel the just the portions that will get the rock hits. My coating install uses suntek which is thinner than the xpel. They have their positives and negatives, its all about time and money sometimes. Personally I want to at least do the film protection roughly $1500 in suntek for critical areas, I am on the fence about the coating as it will be around $1900 with a stage 2 paint correction to make it shine and get the swirl out. My truck is black and I coated it, which was the best move I ever did, all I have to do is wash it air dry it and done!
02-14-2018, 03:46 PM | #32 |
Good discussion so far. Hopefully more people than just me will find it all useful. My car is at Status 3000 right now. When she gets here she'll be going right to the PPF shop for front facing areas or rock vulnerable areas and then either a Ceramic Coating or just a Sealant.
02-14-2018, 03:55 PM | #33 | |
Coupe Newbie
02-14-2018, 11:22 PM | #34 | |
If I only apply film I will do stage 1 paint correction. My ZL1 is black too so who knows how bad it might be swirled already. |
02-15-2018, 12:10 AM | #35 |
Coupe Newbie
My car is also black. It had less than 600 miles on it when I had the correction and film applied. I probably washed it three times prior. All the paint damage was the very fine surface variety easily removed with a good polish. Don’t know that i’d get overly aggressive with the correction If I didn’t need to. These cars don’t come with a whole lot of clear from the factory.
02-15-2018, 11:14 PM | #36 |
Drives: 2013 2LT RS, 2017 ZL1 Join Date: Jan 2013
http://www.camaro6.com/forums/showpo...7&postcount=50
Total cost was 3750 before taxes for xpel in impact only zones, 3 coats of opticoat including wheels, paint correction and tint. He tried to do the grill but said it didn’t look good, so -150 from the price of the front in that post.
02-15-2018, 11:39 PM | #37 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
I used this before events now:
http://www.roadwarriorplus.com/default.asp Roll it on thick! Peel it off when done... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
02-16-2018, 08:17 AM | #38 | |
Drives: 2016 Chevy Camaro SS Join Date: Feb 2016
Roll it on thick, it will protect everything you cover and peel it off when done. |
02-16-2018, 08:33 AM | #39 | |
02-16-2018, 11:01 PM | #40 | |
Cal
02-17-2018, 08:13 AM | #41 |
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Dec 2016
I did Xpel for the full nose of my ZL1 including the exposed carbon fiber and mirrors. $1,750. Rockers up to the crease in the door added another $400. Then I did Ceramic Pro Silver over everything for a bit over $750.
This set up has worked great for over 10K miles and some extreme winter action. It cleans up great with no swirls, chips, etc... yet. I would do this again in a minute. Xpel over everything is an overkill. The ceramic coating adds a hardness and resistance to scratches that they stock paint does not have. It also makes the wheels easier to clean when brake dust gets on them.
- Life is a highway... I want to ride it all night long...
Sold 2010 997 GT3, 2016 WRX, 2006 997 C2S, 2003 996 C4S, 2001 Boxster S, 1997 E420 AMG etc.. |
02-17-2018, 08:39 AM | #42 | |
Cal
