03-22-2020, 12:35 PM | #1 |
Valkyrie14
Drives: Chevrolet Camaro SS Join Date: Mar 2020
Coil Pack Questions
I am considering a coil pack upgrade/replacement. I have headers and a custom tune. I have NOS put have no plans to use it anytime soon. I see a lot of options with varying degrees of ohm resistance. Any of this make a difference? I don’t go to the track, which packs should I be looking at? Or should I just get replacement OEM packs?
What have you done? And would you do it again?
2014 SS LS3/LSA Supercharger, 10% Super Damper, 2.55 upper, AGP Dual Pump, ID 1050 injectors, Pegasus solid rear cradle bushings, LT Headers, Roto-Fab CAI, Elite E2 catch can, E85 corn fed, 160 Thermostat, Monster Twin Disk, MGW Short Throw shifter, Tick Clutch Master Cylinder, HP Tuners, JL Audio system.
03-22-2020, 01:47 PM | #2 |
Drives: 2010 2SS, 2017 Silverado LTZ Join Date: Jan 2007
The stock coil pack will work fine. I have 68K miles on my 2010 SS with a supercharger. See below for mods.
2010 2SS/RS Victory Red, MN6, 1-7/8 Kooks LT Headers, SLP Axle Back, Edelbrock E-Force S/C, ZL1 Fuel Pump, 72# Injectors, JRE fuel rail upgrade, Roto-Fab CAI, Elite Catch Can, Billet Hurst Shifter, DSS 1000HP axles, Spohn Trailing Arms, Toe Links, Lower Control Arms. Chrome American Racing Torq-Thrust wheels. 546/rwhp & 522/rwtq & 10.9# boost Tune by Jeremy Formato.
03-22-2020, 02:27 PM | #3 |
Tri-County Camaro SWFL
From my understanding coil packs dont need to be replaced or upgraded unless they arnt working properly even with power adders OEM coils are fine
03-22-2020, 02:53 PM | #4 |
An N/A motor doesn't need upgraded coil packs. More spark energy doesn't help
much N/A. As the plug tip wears, and the gap widens, maybe, but when boosted it helps to prevent spark blow out under boost. There's just no real need for more spark energy with an N/A motor, unless you're making your own fuel that requires it. |
03-22-2020, 04:32 PM | #5 |
Valkyrie14
Good to know, I did the light test on all of the packs by unplugging the pigtail. The engine made a slight change in noise. I checked the 1&3 cylinders with a multimeter and they read .3 -.4 ohms. I guess that is acceptable but on the low end. I am doing plugs and wires and part of me just wants to change the packs. I grew up changing the distributor as part of any tune up and it feels like changing the packs is part of the tune up.
03-22-2020, 06:11 PM | #6 | |
Drives: ABM #93 Join Date: Oct 2018
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
03-22-2020, 06:28 PM | #7 |
Valkyrie14
i guess I will test the rest of the coils so I can be sure
03-22-2020, 06:48 PM | #8 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
The only time you need to replace a coil is when it doesn't work anymore. Simple as that.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
03-23-2020, 04:42 PM | #9 |
Sporting Foole
Drives: 2010 Camaro SS Join Date: Sep 2019
Yabbut
I want some-A them purty red ones? |
03-23-2020, 05:41 PM | #10 | |
I painted mine, they need touched up though. I wasn't about to spend $450 for the red MSD coils just for a red theme. I want to find black bolts as I tried painting mine but as soon as you put a socket on them the paint flakes off.
03-23-2020, 05:50 PM | #11 |
I believe hot rods 4.8L Big Bang theory made 1200+ on stock coils. the later Big Bangs May have had stock coils as well I can’t remember.
03-23-2020, 08:16 PM | #12 |
NEcamaro5
I didn’t like the look of the coils so I mounted them under my radiator. Stock are all you will ever need.
03-23-2020, 08:29 PM | #13 | |
You have any pictures of your mounting job?
03-23-2020, 08:46 PM | #14 |
NEcamaro5
I can take som pics after work tomorrow. I did the valve covers and the coils just did t do it for me. I did the keto Valve cover brackets and no they are in the tool box. I will say two years ow and all is good. Plus they stay cool down below.
