06-03-2018, 09:19 AM | #1 |
Drives: 2ss Join Date: Oct 2009
2010 SS L99 lsa swap questions
I have all parts to convert to ls3 and I'm using BTR stage 2 PD cam. I was wondering how car would perform with that cam before I get blower put on. I do have the blower, but I need a few parts to finish the build. Tuning is not an issue its free..
Thanks in advance Kirk |
06-03-2018, 10:23 AM | #2 |
It should be a nice bump in power for the time being. I would wait it out though since you're going to have to pull the balancer again to do the blower. It would be easier to do it all at once. If you need any other parts for your LSA set up let us know. We can get stock or aftermarket balancers, pulleys, heat exchangers and more.
06-03-2018, 02:00 PM | #3 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
Ditto, do it all at once. That is what I did when I did my LSA conversion 4 years ago...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
06-03-2018, 04:58 PM | #4 |
I've been under the assumption that there are bracket kits out there that allow you to use all stock Camaro accessory drive including the stock balancer.
Thanks Kirk |
06-03-2018, 09:17 PM | #5 | |
-Don
747 RWHP 794 RWTQ
06-04-2018, 10:18 AM | #6 |
Thank you Hammdo for your help, read your build thread on the install. Makes me want to get started. Thanks Kirk
06-04-2018, 11:48 AM | #7 |
Drives: too many to say! Join Date: Nov 2010
06-04-2018, 12:15 PM | #8 |
Anytime!
Here is the install guide: https://www.camaro5.com/forums/showthread.php?t=514480 I happen to have that pulley setup with spare pulleys (upgraded to full 3 belt LSA so don’t need it)... $150 shipped PayPal goods and services ;o) -Don
747 RWHP 794 RWTQ
06-04-2018, 12:29 PM | #9 |
Does it matter that my LSA is used from a CTS-V, as far as belt spacing?
06-04-2018, 12:42 PM | #10 |
Fish-man, that was the plan, to pin the balancer during the cam swap, but others in this thread had said that the balancer had to come back off for blower. Was confused but hammdo cleared it up for me... Thanks Kirk
06-04-2018, 12:49 PM | #11 | |
Also, if yours is a ‘true’ LSA (block) and your dropping in the engine to replace your current LS3/L99, make sure you have a compatible flywheel as the LS3/L99 flywheel is different than the LSAs... -Don
747 RWHP 794 RWTQ
06-04-2018, 12:54 PM | #12 |
I was planning on using all my stock L99 stuff..
06-12-2018, 10:35 PM | #13 |
Hammdo, how long did you run the 6 rib and why did you upgrade? Thanks in advance Kirk
06-13-2018, 12:28 AM | #14 | |
-Don
747 RWHP 794 RWTQ
