12-14-2016, 06:02 AM | #1 |
Lashu74
Drives: 2017 ZL1 Join Date: Dec 2014
2015 1LE all season tires on 2017 ZL1
Not sure if this has already been addressed I did some searching and couldn't find anything. I have a set of Michelin sport all season tires 285 35 20 from my 2015 ss 1le and would like to put them on a set of MRR MO17 rims to use in the cold weather on my 2017 ZL1. I know the tires on the 2017 zl1 have a 30 aspect ratio not 35. I also know it will affect the speedo a bit. My question is will I have any fitment issues going from a 30 to 35 aspect ratio? Has anyone done this? Pics?
12-14-2016, 06:48 AM | #2 |
Drives: 20 X3M CP & 19 ZL1 1LE A10 Join Date: Jun 2013
I play here when I'm about to change tire sizes, etc.
https://www.tacomaworld.com/tirecalc...0r20-285-35r20
🔺22 RS E TRON GT
🔺21 Model S Plaid |
12-14-2016, 12:12 PM | #3 | |
Drives: 2017 ZL1 Join Date: Aug 2016
12-14-2016, 12:30 PM | #4 | |
Drives: 2016 Camaro 2SS Join Date: Jan 2015
12-14-2016, 01:58 PM | #5 |
Width won't affect speedo. Aspect ratio can depending on the difference.
🔺22 RS E TRON GT
🔺21 Model S Plaid |
12-14-2016, 02:02 PM | #6 |
🔺22 RS E TRON GT
🔺21 Model S Plaid |
12-14-2016, 02:41 PM | #7 |
Lashu74
Thanks for the reply I actually have been on that site and I knew the diameter was a little more than an inch bigger. I guess it's just a matter of measuring and see if I have the clearance. The other concern is the offset is a little different on the front MRR rims I believe it's +23 instead of +20. I was just hoping someone might have already done it so I could know indefinitley. Thanks for your help!
12-14-2016, 05:39 PM | #8 |
Drives: 2015 Sierra Join Date: Apr 2016
Width will affect it because of the aspect ratio. 275mm wide x 35% will be shorter than 305mm wide x 35%. The 35 is the percent of the width of the tire that equals the height of the sidewall.
12-14-2016, 05:43 PM | #9 | |
We are talking 30 vs 35 on same width. <------
🔺22 RS E TRON GT
🔺21 Model S Plaid |
12-14-2016, 07:20 PM | #10 |
Drives: 2013 ZL1 M6 Join Date: Oct 2013
It will be a roll of the dice. The ZL1 is not on a square set up of 285 at all.four corners.
The stock tire size diameter is 26.7 front/27.2 rear. The car is calibrated to this data. The size, if I am reading that you will go square at 285 35 20 at each wheel this data comes out at 28.4 at each corner.. The car computer is expecting the diameter difference to be 1.5 inches and may throw abs and stabilitrack codes and problems. Peole who have run a square set up front and back on these newer cars have found they must adjust the aspect ratio to keep the original difference in diameters the same. |
12-14-2016, 10:09 PM | #11 |
Lashu74
Did you mean .5 difference? Just making sure I'm understanding what your saying. Do you think I could just purchase a set of 305 35 20s for the rear and run the 285 35s on the front? I'm just trying to use what I already have cause they're like brand new. I guess it's more of a question if 35s will work. Thanks again for the replies!
12-14-2016, 11:10 PM | #12 | |
I do know that too big of a difference greater than a half inch will cause issues, so if the car is expecting a half inch difference and does not see it at the wheel sensors, that could possibly do so as well. http://www.camaro5.com/forums/showthread.php?t=239966 |
12-15-2016, 05:24 AM | #13 |
Sorry, I completed misunderstood when the guy above asked why changing the width would effect the speedometer and you said width doesn't effect that, my mistake. I'll go back to trolling and let the adults handle this.
12-15-2016, 04:02 PM | #14 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
If the Camaro is anything like the C6 and newer Vettes (which have always ran factory staggered tires) then as long as you don't go over 1" in tire height differences you will be fine. There is some tolerance built into the system due to tire manufactures having varying tire heights.
