12-10-2016, 07:23 PM | #1 |
Drives: 2017 ZL1 HBM, M6 Join Date: Oct 2016
Skip shift in 2017 ZL1
I did a search and found LOTS of info. But could not find one for the 2017 ZL1. Does the 2017 ZL1 have skip shift. We already have to pay the gas guzzler tax, so do we also have to have skip shift?
If we do have it, is the skip shift eliminator the only way to get rid of it? (Other then a custom tune) |
12-10-2016, 08:01 PM | #2 | |
12-10-2016, 08:10 PM | #3 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
Yes it has it. Find the skip shift solenoid on the tranny and put a $1.50 2.2k resistor in the end of the wire. Problem solved. The 99 Camaro and Trans Am both used the 2.2k. I doubt they've changed anything on the skip shift to require a different resistance to keep the trouble light off. If I had a new M6, that's the first thing I would do.
I would think you should be able to use an ohm meter to read across the solenoid and verify the resistance. If I remember right, the solenoid was on the driver side up near the top of the tranny.
Life's Short, Live Fast! https://youtu.be/rTUv2p4T7OA 10.94 at 128 mph, 11.13 at 127mph 870 DA, https://youtu.be/e_X_LcpFp50 11.19 at 127mph 1100 DA, https://youtu.be/OXQiCQdQuH4 11.40 at 125mph 1800 DA
https://youtu.be/uWba1qs8M6Q 11.52 at 123mph 3500 DA TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
12-10-2016, 08:24 PM | #4 |
Drives: 2016 Camaro SS M6 w/ NPP Join Date: Jun 2016
Use more than 33% throttle and problem solved
Whipple 2.9, Custom New Era Performance cam,
E85, LT4 fuel system, Motec powered port injection, teeny tiny Nitrous Outlet system, Stainless Works LTs, Centerforce Triad, GForce 9" with strange pro case 3.50 gears. Carlyle 15" conversion 28"x10.5" MT ET Drag 28"x4.5" M&H fronts PB: 9.569 @ 151.05 |
12-10-2016, 08:36 PM | #5 |
Drives: 2017 ZL1 Join Date: Aug 2016
What is the 1-4 skip shift? How does this work on manual?
12-10-2016, 08:39 PM | #6 |
It locks out 2nd to make you shift into 4th on light accell from a stop
12-10-2016, 09:19 PM | #7 |
Drives: Red Hot track candy Join Date: Oct 2009
I was a bit annoyed to find out it had it on this gen too but I will tell you that it is way less noticeable on this car. It rarely locks me out. The surefire way to avoid it is to throw technology (and EPA BS) right out the window and do the exact opposite of the intended purpose...throttle down!
When I get mine to about 1200-2000 between shifts it does not seem to activate the skip. And its more fun. I can afford the gas.
Baby born 11/08/16. Left birthing place 11/25/16. Arrived home 12/6/16: '17 Red Hot ZL1. Stock.
12-10-2016, 09:42 PM | #8 |
Thanks for the information guys. Received an email from my dealer indicating it will be here before Christmas!!!!
12-10-2016, 11:44 PM | #9 |
Well Merry Christmas to you!!! Congrats!!
12-10-2016, 11:50 PM | #10 |
Why in God's name would they put this feature on this type of car??? By far the stupidest thing chevy could of done. It's a 650 hp camaro and they're worried about fuel economy... Who gives a shit.
12-10-2016, 11:52 PM | #11 |
Wicked ZL1
It avoids the Gas Guzzler Tax on the SS's, maybe makes it less of a Tax on the ZL1's...
2017 Hyper Blue Metallic ZL1 A10/CF Hood Insert/PDR/NAV MODS: Rotofab CAI/V-MAX CNC Ported Throttle Body/Clear Bra/LED Reverse Light/Rock Guards/Lift Pads/Darkened Tail Lights/Ghost-Tinted LED Side Markers/Darkened 3rd Brake Light
12-11-2016, 12:04 AM | #12 | |
12-11-2016, 12:16 AM | #13 | |
Moderator.ca
Want to avoid it? Drive the car like the engineers intended when they programmed the parameters to skipshift. Give it some gas, go a bit faster before shifting, and in general have some fun with your 650 hp Camaro. If you are so not concerned about fuel economy ... don't drive economically. I'm sure the engineers that came up with it 25ish years ago shake their head every time they hear someone complain.
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
12-11-2016, 05:30 AM | #14 | |
Drives: C4,C6 Z06,Silverado,'17 Red Hot ZL1 Join Date: Aug 2016
I have the skip shift on my Corvettes, but it has only bothered me once in the decades that I have had them (actually not even once, but I wanted to see how it worked one time...lol). I guess I am driving my sports car appropriately I cannot imagine being able to drive my ZL1 slow enough to hit the skip shift...and if you are concerned about traffic, take off out of second gear and you will avoid the skip shift all together |
