Old 06-17-2018, 07:16 AM   #15
Mavericka70
Drives: '17 1ss m6
1ss with MRC and Bmr springs, rides great.
Mavericka70 is offline   Reply With Quote
Old 06-17-2018, 02:04 PM   #16
bpang1234
You can only YOLO once.
bpang1234's Avatar
Drives: '16 2SS & '15 Subaru Forester
https://www.bmrsuspension.com/?page=...=120&catid=438
2016 Camaro 2ss
-Summit White / Ceramic White
-8A, NPP, MRC, Ceramic White package plus knee pads, black bowties.
-1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns.
-1st Car to have the 6LEDesigns Blade Spoiler.
-Borla S-Type w/ custom H-Pipe
-Procharger P-1X Stage 2
bpang1234 is offline   Reply With Quote
Old 06-17-2018, 02:26 PM   #17
Camarentino
Camarentino's Avatar
Drives: 2018 Camaro 1SS 1LE
@soleil your car is lowered perfectly in my opinion. I just can't find that part on the st-suspension.com website. It only shows 2010-2015 springs. Do you have a part #?
2018 Camaro 1SS 1LE w/PDR Summit White
KN intake-MBRP cb- 2nd cat deletes- ACS sides- iroc Z spoiler- Eibach Pro- Katech 95TB- MSD Manifold-GM strut bar- Custom tune by Arun Ahuja @ CCPERF.ca
Camarentino is offline   Reply With Quote
Old 06-17-2018, 02:37 PM   #18
Camarentino
Ok got it part #28261011 on st-suspension.net. 20mm front and rear but yours looks lower than that. What is your tire size ?
Old 06-17-2018, 03:04 PM   #19
Soleil
Soleil's Avatar
Yep, that’s the one I use still the OEM 20” wheels
Soleil
Old 06-17-2018, 03:17 PM   #20
Camarentino
I wonder why they don't list them in NA? I will email st USA and find out wtf. Thanks
Old 07-06-2018, 03:25 PM   #21
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
Originally Posted by Mountain View Post
Just a fair warning, if you lower a SS 1LE or ZL1 past 0.5" you begin to really FUBAR the roll-center of the front suspension. After that, you need to stiffen the springs up quite a bit to get the same roll-stiffness. If you just care about the looks, then that statement means nothing to you.
Apparently BMR has done track testing with their lower springs on the MR.
Old 07-06-2018, 10:32 PM   #22
Tuner2muscle
Drives: 2019 Camaro ZL1
1LE lowered
V6 lowered...aFe lowering springs
Tuner2muscle is offline   Reply With Quote
Old 07-07-2018, 05:55 PM   #23
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
Oh my God. There is a child trapped in the back
Qik save them
Old 07-07-2018, 11:40 PM   #24
Tuner2muscle
what the deuce... what is she doing in there.....
Old 08-17-2018, 03:57 PM   #25
SaphfireSS
Drives: 2017 Camaro 1LE SS
You have your info backwards mountain. It effects the rear more. Front feels fine. The rear has a slight bounce at high speed rebound. They can’t figure out a better spring rate for the rear. The more they lower it the more it bounces. Trust me I know. I have them on my SS 1LE and it has slowed me down about .5-1 sec on a very familiar 2.7 mile road course.
SaphfireSS is offline   Reply With Quote
Old 08-17-2018, 04:02 PM   #26
SaphfireSS
Old 08-17-2018, 04:40 PM   #27
TRZ06
TRZ06's Avatar
For a MRC car, I think the best thing to do spring wise is keep stock ride height and just use stiffer springs. Lowering a MRC car is not good in general as the programming no longer matches.
I went thru the same issue on my Audi TTRS which also used the magnetic dampers. There was a need for springs on the TTRS though and I used MSS springs. They firmed things up, dialed out the understeer, and eliminated the dive/squat, but they didn't lower the car from stock. It worked great and didn't negatively affect handling. Granted they consulted with the program engineers from Audi who tuned the TTRS and spent a lot of money on R&D and track testing to make sure they didn't muff up the handling.
Honestly, I do not think that the 1LE needs to be any lower than it is stock, as far as wheel gap, there is minimal to begin with. I would only add springs to that car to stiffen it up some.
That is the one thing you have to get used to with MRC cars, the spring rates do not need to be as high as normal because the MRC shocks can tighten things up a lot more than standard shocks, but the offset to this is the car feels a little wishy washy at low speeds because of the softer springs and no need for the shocks to tighten way up say like when going over speed bumps or driveways.
The 1LE has no brake dive when braking hard to speak of, so there is no reason for stiffer springs there, but it could use less squat, however when I put the solid rear cradle bushing in from the ZL1 1LE kit, that will probably reduce that.
So in conclusion, the 1LE doesn't need a spring change if you care about performance first and looks second.
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 08-27-2018, 02:20 PM   #28
USAFS197
USAFS197's Avatar
Drives: 2018 Audi TT RS
I'm looking forward to that cradle kit feedback. I've been eyeballing the BMR cradle stuff for some time now and I'm always more interested in OEM offerings before going aftermarket.
2018 Audi TT RS
2019 Audi RS3
About as fast as the TT RS
2019 Camaro ZL1 1LE
Sold
2018 Camaro SS 1LE
Sold
2019 Corvette Z06
Sold
Sold
