11-08-2020, 11:33 AM | #1 |
Drives: 2020 1SS 1LE M6 Riverside Bl Metall Join Date: Oct 2020
Front Brake Ducts For Track -Clarification?
I have read the Owner's Manual section (pgs 160-162) regarding Front Tire Deflectors, Lower Control Arm Deflectors and Disc Splash Shields. As far as I can tell my 2020 1LE did not come with any of those either on the car or in the trunk. I want to take advantage of what Chevrolet developed for ducting for the front brakes for Track Days. Part Numbers would be helpful.
P.S. I know this has been mentioned in several threads but I have not been successful in finding a detailed discussion on this subject. |
11-08-2020, 11:40 AM | #2 |
This kit replaces the factory brake duct and splash shield and has parts for both sides.
https://www.gmpartsgiant.com/parts/g...-84145204.html |
11-08-2020, 02:45 PM | #3 |
Thank you! And I googled the part number and it has been replaced by #84433357 ($28.96 list price). It comes with 4 pieces (deflectors/shields) and the description "brake cooling for track use".
Any tips on installation? Last edited by Fast Ken; 11-08-2020 at 07:52 PM. |
11-08-2020, 02:53 PM | #4 |
Drives: 2017 1le current /2015 2ss 1le sold Join Date: Jan 2016
Easy peasy and they work !
2017 1LE Hyper Blue
11-08-2020, 06:40 PM | #5 | |
Drives: 2017 1SS 1LE Join Date: Jun 2016
That being said, keep in mind these are NOT needed for an SS 1LE using stock brakes. That's why you didn't find them in your trunk. These were developed for use on the SS because the 4 piston brakes are a bit too small to handle track use without extra cooling. Unless you're overheating the brakes (more aggressive pads or driving 10/10ths in hot weather kind of thing) all they really end up doing for the 1LEs is making clearances smaller (sometimes even rubbing depending on suspension position) and throwing more crud at the rotors that cars in front of you are kicking up. They will make temps cooler, but it's not required on the 1LE like it is for the SS. You can still run them if you want, completely up to you.
2017 SS 1LE.
11-08-2020, 07:42 PM | #6 |
....That being said, keep in mind these are NOT needed for an SS 1LE using stock brake pads for track days.....
This is true |
11-08-2020, 07:55 PM | #7 | |
11-09-2020, 11:06 AM | #8 |
2017 SS 1LE.
11-09-2020, 11:45 AM | #9 |
yup i leave mine on year round!
11-09-2020, 11:16 PM | #10 |
Drives: 2017 Blue Camaro 1SS 1LE with PDR Join Date: Sep 2018
Same. I didn't install the metal shields. The bolt heads snapped off of my two inner bolts probably from all of the scraping which wasn't a problem but just recently one of the middle heads snapped off too when I checked to make sure it was tight after an alignment so I bought some extractors to remove what's left in there so I can replace it. A few zip ties are holding on ok temporarily though.
I would recommend replacing the 6 small stock bolts when you install the track deflectors. Lowes has some that take the same socket size and are just slightly shorter. Also I lost 2 of those 6 bolts previously when the alignment tech didn't tighten them enough so hard to find a safe tightness/torque for them...maybe thread locker would help? Also make sure to follow the wiring clip instructions. You push the clips up from below otherwise the wires could be damaged on full steering lock. You can probably install them with the car on the ground at full steering lock but easier to do it from under the car. |
11-10-2020, 11:01 AM | #11 | |
yea i just looked under my car the other day after i plowed over a cone at the track and my deflectors are rubbing on the ground when i go up/down driveways i believe haha had em on for over a year or so no problems and dont really drive in the rain
11-10-2020, 10:48 PM | #12 |
I believe my first bolt head broke off a little over a year after I installed the track deflectors. It would have been a lot easier to replace them with new bolts before that happened!
11-12-2020, 11:50 PM | #13 |
Drives: 2018 ZLE Join Date: Jul 2014
Im still amazed these dont come on the ZLE
11-13-2020, 08:34 AM | #14 |
Why's that? The SS needed them because the brakes and OE ducting are undersized compared to the braking (i.e. thermal energy dissipation) needs on track from the factory. SS 1LE, ZL1, and ZLE don't have that issue, so there's no need to develop and include this kit for the trims above the SS from the factory.
2017 SS 1LE.
Thread Tools | |
